Seat Question
Old 04-15-2016, 05:04 PM
dmag67's Avatar
dmag67
dmag67 is offline
Seat Question
Will bucket seats out of a 1996 F250 fit into my 1973 F250 without modification?
Old 04-15-2016, 08:42 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
Bench that would be a yes, buckets....well all depends on the mount feet lay out of the buckets. As in there could be a height difference between the front and rear tabs, you might have to bend a tab flat. And I am sure the original bench sliders mount points will not work either.
You might be able to take the bench off the lower frame, leaving the sliders attached. Take the brackets off the bottom of the buckets and set the buckets and the center console on the original bench frame.
Old 04-15-2016, 10:35 PM
dmag67's Avatar
dmag67
dmag67 is offline
From this <br/>
Old 04-15-2016, 10:38 PM
dmag67's Avatar
dmag67
dmag67 is offline
To this
Old 04-15-2016, 10:40 PM
dmag67's Avatar
dmag67
dmag67 is offline
Old 04-15-2016, 10:43 PM
dmag67's Avatar
dmag67
dmag67 is offline
Old 04-16-2016, 05:53 AM
dmag67's Avatar
dmag67
dmag67 is offline
I hope this seat will work
Old 04-16-2016, 09:13 AM
84espy's Avatar
84espy
84espy is offline
Nice looking truck. If you have some fab skills, the seat will work. Take measurements, sit down, draw it out and then start making the brackets. You can do it!
Old 04-16-2016, 09:28 AM
77&79F250's Avatar
77&79F250
Like I said take the original bench frame and see if the buckets will set on there. That way you can reuse the original sliders mount holes.
If it will work then split the frame get to more sliders and there you go.
Cntrylife
09-20-2018 04:55 PM
F-47 Vantablack
31
07-13-2017 11:12 PM
hillbillydeluxe4x4
11-08-2008 11:14 AM
frederic
15
08-21-2005 10:39 AM
badboyina67
04-01-2003 01:42 PM
Quick Reply: Seat Question
