F250 steering - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 steering
Old 04-15-2016, 10:43 AM
Hagefied Hagefied is offline
Hagefied is starting off with a positive reputation.
F250 steering
Hi, I'm new to the forum, not to F250's. My last ones were a lot older though. I have a 2010XLT. I'm having an intermittent steering problem. When cold, the wheels won't return to straight after a turn. If I manually correct, it skips to the other side. I can't even hold it straight. It's either right or left. Only fix is to pull over and turn the wheel from right stop to left stop 4-5 times. Had it looked at twice. Of course didn't happen to on test drives. Any help appreciated.
Old 04-15-2016, 11:06 AM
Firekite's Avatar
Firekite Firekite is online now
Shining Adonis
Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.
Who looked at it? Did they have any suggestions when you described the behavior?
I honestly have no idea myself. It sounds like something is getting stuck in the steering box. I'm sure you've already checked all the mechanical steering components, right, like the drag link and so on? Assuming the power steering fluid is clean and clear and at the proper level, assuming there's nothing in the lower steering components or knuckles that are getting stuck, I'd say maybe replace or rebuild the box.
Old 04-15-2016, 11:11 AM
droldsmorland's Avatar
droldsmorland droldsmorland is offline
droldsmorland has a good reputation on FTE.droldsmorland has a good reputation on FTE.
How many miles on it? Inspect the tie-rods, BJs and the front outer ujoints. The ujoints can cause all sorts of steering problems if they are seized or rusted up tight. Will the ujoints accept grease? When greased do you see it coming out of all 4 caps per side?
4WD should be activated at least once a month. The front drive shaft and outer front ujoints will wick in moisture(car wash, rain, snow) from being static and fail prematurely due to non use.
Old 04-15-2016, 11:12 AM
seville009 seville009 is online now
seville009 is starting off with a positive reputation.
I had something like that happen after I had the tie rods replaced. It was so alarming that I had it towed back to the shop because I didn't know what was going on. So.....check the tie rods.
Old 04-15-2016, 11:15 AM
Squisher's Avatar
Squisher Squisher is offline
Squisher has a good reputation on FTE.Squisher has a good reputation on FTE.
Yah something in the front end will be to tight. Whoever inspected it missed something. Any front end work recently done?
Old 04-16-2016, 09:04 PM
Thanks
The answers to my my thread gave me some new thing to check out. My F250 has 97k on it. 4wd and hub work great. Had right tie rod end done at dealer under warranty in Nov. They checked out rest of from end and said it was good. I'm going to re-lube what I can. Another thread mentioned the steering stabilizer issues. I'll check these thing out and post my findings. I appreciate the help. Thanks
96 F250 4x4 steering issue Jgostrenga 1987 - 1996 F150 & Larger F-Series Trucks 1 08-08-2016 12:09 PM
steering stops on 54 f100 MIKEDEL 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 05-05-2016 08:22 PM
Steering issue. 83capril 1987 - 1996 F150 & Larger F-Series Trucks 4 09-24-2015 04:25 PM
Roaring Noise palbertsen 2004 - 2008 F150 4 05-28-2015 03:29 PM
steering wheel not centered davidsheets 1999 to 2016 Super Duty 15 01-29-2010 11:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
