Semi stripped oil drain plug on my 5.4l3v
Like the title says, I really can't see if the pan threads are bad also or not. My question is what is the best fix for this problem? On a side note, I have in the past been lead to believe that the plug material is softer than the oil pan material for just this reason and therefore the plug will strip and the pan will be unaffected? any thoughts here?
...The truck isn't in my sig, the forum won't let me edit it for some strange reason, The truck in question is my 2007 F250 5.4l 3v engine.
Thanks for all the advice people. I have no idea how the drain plug got damaged, it has been that way since I have owned the truck......it appears like maybe it was over tightened at some point I am going to get a new plug and try it first and if that cleans up the threads in the pan so the plug works easy I'm going to get a fumoto valve for this truck and my 6.0 and eliminate the plug removal and replacement every oil change which will end the possibility of the same problem in the future.
Flaflathead
03-24-2006 06:23 PM
