1994 Ford F150 4x4 Indicator Switch
I've been diagnosing my 4x4 indicator light on the dash not coming on. I've found a switch on the transfer case that is caked up with mud, and I found the connector on the harness. I tested the bulbs themselves by grounding on the the two pins on the connector that is on the wire harness as the lights do come up. Does anyone know where I can get the pigtail which goes from the switch on the transfer case to the connector on the harness? I'm going to get that harness first and if the switch doesn't work, I'll replace the switch.
Thanks!
Thanks!
fordf350man
04-01-2017 11:04 AM
F150Traveller
04-01-2015 09:00 PM
Nightstick180
03-25-2013 06:33 PM
F250GH
01-25-2009 09:08 PM
