2WD 2004 Excursion Front Bearings Giving Me Fits
Old 04-25-2016, 01:21 PM
az_r2d1's Avatar
az_r2d1
az_r2d1 is offline
Originally Posted by speedyweasel
Thanks, gang. I went through the bearings again and followed the procedures above (tighten, rotate, loosen, repeat) and reinstalled the wheels.
The bearing noise is virtually gone.
The wheels have no play whatsoever, but they still freely spin.
Road noise is considerably less and there's no ominous rubbing noise while cornering.
FTE rocks.
Good stuff. You checked with he wheels off the ground, right ?
Old 04-25-2016, 02:20 PM
speedyweasel's Avatar
speedyweasel
speedyweasel is offline
Yes. All adjustments and checks were done with the wheels off the ground.
Old 04-25-2016, 02:23 PM
speedyweasel
Originally Posted by hav24wheel
Just a heads up, make sure the grease you use is spec-ed for Ford wheel bearings. A lot of wheel bearing grease isn't up to Ford specs. By looking at the nice black color of yours, it might not be the good stuff.
Just noticed this post. I should point out that the image was from the first time I did the bearings (didn't take pics this last go-round) and that's BEFORE removal so it's not my grease. The stuff I used to pack them in each instance was some decent-quality red lithium grease designed for disc brake-equipped vehicles. I pack them thoroughly to coat every surface with just as much grease as it'll hold, then smear a layer on the outside, on the surface of the race and slop a wee bit more on it even after installation.
Old 04-25-2016, 02:58 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
FTE rocks.
You only make this mistake once, well, more accurately stated, you won't make this mistake again once you learn the proper way to seat, back off, and then properly torque the bearings when installing.
That is not the voice of experience talking....honest....
Ok, I'm lying.
Hmmm, do you mind explaining in detail how you define the word "pack" as you use it regarding your bearings?
Stewart
AMG-SM
06-13-2014 07:30 PM
scurbiedog
1978 - 1996 Big Bronco
08-02-2013 09:10 PM
35l911
1983 - 2012 Ranger & B-Series
06-28-2007 09:08 PM
twjull
1999 to 2016 Super Duty
08-29-2006 11:28 PM
Quick Reply: 2WD 2004 Excursion Front Bearings Giving Me Fits
