rear brake line size
I had a brake line crack on my way home yesterday(that was interesting..) It was the drivers side rear metal line from the splitter to the rubber hose. I went to autozone and was like ok easy enough this line is the same length and appeared to be the same diameter. bend to fit and all was well or not.. the fitting on the end was a differnent thread pitch and size. Can someone please point me in the direction of proper sizes and thread types and such?
e99 f250 4wd if it matters
Can you cut it at the flair and use the old male threaded plug and re-flair the end? That would be the easiest to do.
Yes the year does matter. Beginning 4/99 things changed with the Brakes.
I can find the part in the system, just no specifications on size / pitch /thread
Ford Parts (Brakes): http://goo.gl/qcTcZu
Call a caliper rebuilding service, and ask them. I bought rebuilt calipers & new rotors from Powerstop, actually had really great service from them for a bunch of stuff. Anyway, I changed the flexible lines as well (can't remember if I bought all from Powerstop). I have a 02/99 truck, and they knew enough to send me the correct calipers that fit right in. At the time I did not know the difference about early / late 99's beyond engine stuff.
Sooper Camper
05-08-2013 11:38 AM
oldcoupe42
07-25-2010 11:01 AM
crashed13
10-20-2008 10:45 AM
Pele
06-02-2007 09:21 AM
