A drop from the road draft tube and ocassionally some from the turbo pedestal (until I instal the Riff-Raff delete pedestal) then, just the road draft tube....
Man, my truck is like an alpha dog ever since I got it, seems like it marks everything. First it was a oil leak from the drain plug washer, then an oil leak from a loose valve cover, then a coolant leak, then another coolant leak from the water pump crapping out, and now an axle seal leak..... its endless.
between my hydraulic tank, seeping front axle seals, possible oil pan gasket, and the dip stick adapter. Mine plays the role of dominate male in walla walla Washington. Dust control, that what I use mine for too. Ha ha ha
