Modular V10 (6.8l)
What the heck?
Old 04-14-2016, 11:22 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Did you ever check the bellhousing inspection cover? that thing buzzes like crazy around 1800-2200RPM and can drive you nuts wondering what it is.
Did this just start happening out the blue? Or did it start gradually?
Old 04-15-2016, 12:23 PM
critterf1's Avatar
critterf1
critterf1 is offline
Took inspection cover off. Has been gradually getting worse over time
Old 04-15-2016, 12:28 PM
critterf1's Avatar
critterf1
Originally Posted by Apocalypse
You never answered what plugs you swapped in. Also you might think about running non-ethanol fuel in your truck. It's all I run unless I run low and can't get to any.
Motorcraft SP-479 gapped at .054.
Old 04-15-2016, 12:31 PM
critterf1's Avatar
critterf1
Originally Posted by Im50fast
I had the same issue last year. Catalytic a converters bad.
Checking at the o2 bung won't find it because the back pressure is between the 1st cat and the engine.
Unbolt your exhaust. Look inside with flashlight.
Test drive with exhaust disconnected.
You'll see.
This thing is OBDI, O2 sensor is between the manifold and the catalyst
Old 04-15-2016, 12:36 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
has the inspection cover been off all this time?
On my '01, when I did that and drove it around, the noise was HORRIBLE because the separator plate between the engine and bellhousing buzzed like mad.
The only other suggestion I have is to monitor the PCM with a scan tool that can do data capture and watch the knock sensor PIDs. The knock sensor logic, if I recall correctly only pulls 4 degrees of timing. So even if it is seeing something, it may not be able to do enough in an extreme case. But it will tell you if it at least sees something.
Old 04-15-2016, 12:49 PM
critterf1's Avatar
critterf1
Unless I overlooked it my scanner doesn't show the timing advance/retard on this vehicle. was kind of shocked to find that it's a 2000 model with OBDI.
Old 04-15-2016, 03:53 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
This thread sort of explains that:
https://www.ford-trucks.com/forums/5...t-come-on.html
My guess is a great big vacuum leak. Is this a stock vehicle, no mods at all? It would help everyone to know more about the vehicle you are working on and if your "2000 V10" is still in the same vehicle put it in.
Old 04-20-2016, 08:06 AM
critterf1's Avatar
critterf1
Replaced knock sensor, all is good now.
Old 04-20-2016, 10:11 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Good to know, thanks for reporting back
Old 04-20-2016, 10:20 AM
truckfella's Avatar
truckfella
truckfella is offline
Agreed, thanks for reporting the solution. And, for those of us lucky enough not to have had to change the knock sensor (yet), where exactly is it??
Old 04-20-2016, 02:16 PM
critterf1's Avatar
critterf1
Center of valley under the intake manifold
Old 04-20-2016, 02:56 PM
harley4jcs's Avatar
harley4jcs
harley4jcs is offline
Meaning you had to pull the intake ??
  #28
Old 04-21-2016, 04:25 PM
critterf1's Avatar
critterf1
Not a big deal
  #29
Old 04-21-2016, 06:55 PM
R&T Babich's Avatar
R&T Babich
R&T Babich is offline
What is the part no. ?
Im50fast
Modular V10 (6.8l)
10-11-2015 07:44 AM
KevinAH
2004 - 2008 F150
05-04-2010 04:12 PM
fatherdoug
06-23-2004 11:13 AM
cwgoff
1997 - 2003 F150
04-14-2004 10:42 PM
nothingbutford
Modular V8 (4.6L, 5.4L)
08-18-2003 10:03 AM
Quick Reply: What the heck?
