Suggestion for installing inline coolant filter
Old 04-12-2016, 11:51 PM
coolfeet's Avatar
coolfeet
coolfeet is offline
Can I connect my IPR coolant filter inline with to the heater hose as pointed out in the diagram below?
I want to make sure that installing the coolant filter inline will work. I already have a Sinister Diesel bypass filter and I want to remove it and the T fitting and replace it with the larger IPR coolant filter and connect it inline.
I bought the kit with the manifold that connects to the top of the oil cooler housing. I would rather connect the filter before the oil cooler. I talked with Ed from FICM repair and I think this is what he suggested over the phone.
I have already cut the heater hose for the Sinister. I have enough 3/4" heater hose to mount the filter on the frame rail under the van. I want to use a barb fitting on each hose that goes back to the filter housing.
speedtrapp
10-08-2012 12:49 PM
DieselVol
1999 to 2016 Super Duty
08-13-2012 01:49 PM
036.0stroke
07-26-2012 06:19 PM
gearloose1
04-11-2010 07:09 PM
xlrs
02-20-2006 07:19 PM
Quick Reply: Suggestion for installing inline coolant filter
