South Bend or Luk clutch
I'm looking at replacing my DM flywheel setup. I'm tired of the chatter and the feeling that something is out of balance at times. My question is which clutch is better in terms of longevity. I don't drive the truck much, I don't plan on any motor mods and I don't pull any loads with it. If anyone has any suggestions it would be much appreciated. I only want to do this job once.
I have almost 80k miles on a HD LUK SMF setup... I would have never thought it would have lasted this long considering what the truck is used for and the power output. South Bend is also a great clutch. if you want a stock feel and are going to be running under 300-325hp, the HD LUK is cheap and reliable and feels great. SB are a bit more stiff and grabby considering the masterial they are manufactured with. I think SB has a organic single disk 400hp clutch that I am planning on getting next as long as its compatible with the LUK SMF flywheel.
Don't buy more clutch than your engine needs. If your engine is stock or reasonably close to stock power output, then use a stock clutch.
The reason being is that high-output clutches are designed to transition at a higher power range. For example, say that a 600 hp clutch is designed to slip at 400 hp with partial pedal. Or a 400 hp clutch which is designed to slip at 300 hp with partial pedal. If you put the 600 hp clutch on a 400 hp engine, then what you end up with is no "friction zone" in your pedal. Your clutch will be full on or full off.
