1948 Ford F6 Need to move engine and gearbox
Well, I didn't move the engine yet since the bolts on the trans mount aren't worn and if I move the trans over I'd need to drill. Not good.
The plate came off quite easily when I took the bolts off. It's clean and it great shape.
I'm out of ideas. My clutch equalizer is the correct part number, my socket looks good. I'm still off 1/4-1/2". The rod that the equalizer connects too moves in and out of the clutch housing about a 1/2". I'm clueless about clutches so could the fork be off and require moving down the rod so that the rod wouldn't slop down 1/2"?
The trans cross bracket and trans, etc are level so I don't think it's warped.
Maybe you have the wrong shaft? That equalizer is spring loaded so that it holds the assembly in place against the ball mounted to the frame. Maybe somebody else knows the difference.
From the centerline of the pin that connects the equalizer to the clutch shaft in the bellhousing to the end of the equalizer is 7 5/8". From the centerline of the pin to the edge of the frame rail is also 7 5/8", the end of the equalizer and edge of the frame rail should be in line. From the centerline of the pin to the side of the clutch shaft bushing boss on the bellhousing is 5/8". I hope this all makes sense. These photos and dimensions are from a '49 F4 which would be the same as your F6.
Mark
Mark
If I can slide the equalizer rod (That connects to the equalizer shaft), it could be the fork is off. It looks new inside the clutch
So that rod would be flush with the casing on the opposite side of the equalizer shaft.
Do I need an engine lift to get it out (the trans), I can't lift the truck but could come through the cab...
Thanx.
#29
#30
