break help
Old 04-11-2016, 08:57 PM
stockscooby's Avatar
stockscooby
stockscooby is offline
break help
not sure if this should go here or tech but I need some info on how to clean my break master cylinder. it has a bunch of rust and sludge in it and is pretty empty, how can i clean it out to make my breaks work? thanks for the help
Old 04-11-2016, 09:04 PM
EFranzen's Avatar
EFranzen
EFranzen is offline
Degrease it and then let soak overnight in Evaporust and it will look sparkling new. You will probably need to hone out the bore and then replace the seals afterwards.
Old 04-11-2016, 09:16 PM
stockscooby
someone told me to fill it full of wd40 and wash it out a couple of times? that work?
Old 04-12-2016, 01:19 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
If the master cylinder is rusty, the lines and wheel cylinders probably are as well. You'll need to flush the lines or replace them - same with the cylinders.
I would steer clear of the WD40 and follow EFrazen's advise. You want this clean and rust free - not greasy.
Old 04-12-2016, 01:25 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
No. Petroleum/oil should not be allowed to get anywhere near brake parts and lines inside. It will ruin rubber parts in brakes. The master cylinder will need a rebuild kit. That is, once it has been inspected and determined that it's serviceable and can be honed safely, if the pitting and corrosion can be cleaned up. Most people just buy a new master cylinder.
Old 04-12-2016, 01:35 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
IMO, the only safe way to drive one of these old trucks is after the brake system has been completely rebuilt and or replaced. Replacement should include anything that has a soft part, hoses, cylinders, etc. Steel lines should be pulled loose from the frame and examined thoroughly for rust. Better yet, all brake lines should be replaced.
As Tedster9 mentioned above, keep petroleum products away from the brake system.
Welcome to the forum. What kind of truck are we discussing, F1 or F100 ?
Old 04-12-2016, 03:36 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Personally I replaced mine along with all four wheel cylinders, linings, hoses, and brake lite switch, plus did a thorough brake line inspection and flush. Another thing to think about if you do replace is, do you want the original single cylinder master, a double cylinder master, or a vacuum assisted unit. Parts are sold by most vendors , such as Classic Haulers, Mac's, Dennis Carpenter, Sacramento vintage ford, and many other s that can be found on the net under 1948 thru 1952 F1 parts. Best of luck on your project, and a big FTE welcome from Northern California.
Old 04-12-2016, 09:21 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Be careful! Do good work, don't cheap out on tires or brake parts.
Old 04-13-2016, 12:13 AM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Stockscooby,
Hmmm... Master cylinders... My son brought our F1 back from college with the front chamber
completely empty. Since you are going to have to mess with the master cylinder - might as well
upgrade to a dual chamber unit so your brakes don't all go out at once.
You will need to bench bleed the master cylinder to make sure no air is in it. Normally the replacement
master cylinder should come with a brake bleed kit. We bought our's from Summit - they sell a nice kit there to get power brakes.
Good luck over there & welcome. Pictures are always appreciated.
Ben in Austin
1950 F1
Old 04-13-2016, 04:36 AM
FortyNiner's Avatar
FortyNiner
So Ted, that must be the view of Waterloo from the west, right? Everything looks different from the other directions.
Old 04-13-2016, 11:46 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Ha! Yeah. I've driven this a couple times. In the '64 even many moons ago. It's UT 261 between Mexican Hat and Hanksville. I snatched the pic from here:
http://www.fordbarn.com/forum/showthread.php?t=193764
The Shafer trail is another road that is suitable, iirc, for high clearance 2WD in good weather. The West is full of good, graded dirt road. Stock up on water and some provisions and maybe an extra gas can. Lots to see!
Old 04-13-2016, 12:46 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Yes stockscooby, I agree with Tedster9. Replacement brake parts are easy to find. If you have an old brake part that is rusted and pitted particularly inside replace it. It isn't worth the effort and the danger to you and others.
This is Route 74, the Palm to Pines Highway, above Palm Springs. There are some terrible skid marks with broken guard rails where vehicles could not slow down on curves. Never saw the results but can only image. Otherwise a very scenic drive.
Old 04-13-2016, 01:21 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Iowa - Iowa!! Has one (1) runaway truck ramp! It's true. NE Iowa is reasonably scenic along the Miss.
Old 04-13-2016, 01:57 PM
FortyNiner's Avatar
FortyNiner
That road is a treat. I'm sure the truckers from Pennsylvania or Kentucky just chuckle when they see the sign in Iowa though.
Old 04-14-2016, 08:20 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Had to lock 'em up today in fact. Lots of traffic and then... "all of a sudden"... "Brake Check!"
New springs, shocks, tires and brakes, it handled fine, but don't want any flat spots on new tires either. Locked up all 4 drums!
Ironmike40
05-27-2018 03:04 PM
kedwinh
09-19-2012 09:22 AM
FordPickupMan351w
General Automotive Discussion
01-09-2008 04:24 PM
RDON
12-31-2006 09:20 PM
jfor26
01-13-2006 03:32 PM
Quick Reply: break help
