Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 01-29-2002, 03:08 PM
coops28 coops28 is offline
Garage is empty, add now
coops28 is starting off with a positive reputation.
pcv valve location?
Heres an easy one. Where is the PCV valve on my 94 f150 6 cyl. Thanks.
  #2 (permalink)
Old 01-29-2002, 08:55 PM
EaSTxCOwboY EaSTxCOwboY is offline
EaSTxCOwboY is starting off with a positive reputation.
pcv valve location?
pop open your air box lift up the air filter and walah! there it will be, and on the outside of the air box is a small tube where the air runs through
  #3 (permalink)
Old 01-29-2002, 11:57 PM
PAUL_2 PAUL_2 is offline
PAUL_2 is starting off with a positive reputation.
pcv valve location?
The PCV Valve is located at the back of the valve cover . The PCV Filter is located in the air filter housing , under the air filter .
  #4 (permalink)
Old 01-30-2002, 07:50 AM
TallPaul's Avatar
TallPaul TallPaul is offline
2001 Ford Ranger
TallPaul is gaining momentum as a positive member of FTE.
pcv valve location?
I just went through that--took me a while. It is practically hidden under a hose that runs across the back of the valve cover. If you kneel on the cross member above the radiator and then reach down just behind the intake plenum, you will find it. But why does the valve have two hose fittings and you have to plug one, when I see single hose PCV valves all over the rack?
INLINE SIX POWER!
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
__________________
'01 Ranger, 2.3L, 5 speed, 83,000 miles. Redline MTL, Amsoil Signature 5w20, Wix Oil Filter, Dynomax Super Turbo muffler.
  #5 (permalink)
Old 01-30-2002, 07:53 AM
TallPaul's Avatar
2001 Ford Ranger
pcv valve location?
__________________
Tags
1987, 1999, 2000, 2001, 2002, 2004, 42, explorer, f150, f250, ford, location, navigator, pcv, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
