are bearings in front hub hub replaceable
on
I don't have the number. I tapped it out from the opposite side. Took it to a bearing shop and said "2 of these please" He took a couple measurements, took about $15 bucks from me and sent me home with 2 new bearings! I have to do my recently new to me 2008 right quick here, as well as the u-joints and such.
Needle bearing below:
Ford part number C6TZ-3123-A
2004 F250 Needle Bearing Replacement
You can also grease them through the ABS hole.
2004 F250 Front End Service
RiffRaff sells the zerk:
Front ABS Grease-able Block Off Fitting for Ford 7.3L 99-04
Any BDI (Bearing Distributor Inc.) can get you anything that has a number on it even some that dont. All they need is the critical dimensions and application and they can match it. Generally pennies on the dollar over OEM stealership prices. Just be sure to ask for non-chineasium junk. As thats what they will try to sell you first when there are several alternatives, from Japanese to Swiss to German to USA. All are better then the fore mentioned junk.
