1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Auto Temp panel bulbs 99 Expedition
Old 04-11-2016, 04:21 PM
alz's Avatar
alz
alz is offline
New owner of a 99 Expedition.
Looking to replace a couple of the bulbs behind the Auto Temp Control panel.
I have searched and even tried the dealer. The manual control uses a standard 194 bulb where the ATC uses a different socket and bulb.
Does anyone have a tutorial on replacing these and maybe what bulb they used?
Old 04-25-2016, 05:49 PM
Ristin's Avatar
Ristin
Ristin is offline
Have you taken the unit apart? In my 2000 Expy the bulbs are soldered to the circuit board. I Got some replacement bulbs on line. Didn't know what part number so I bought some that looked similar. They turned out to be slightly smaller and dimmer but they work and the brightness difference isn't to noticeable.
Old 05-02-2016, 04:37 PM
alz's Avatar
alz
alz is offline
Just an update. I tried replacing the bulb with some I had at work but they ended up being less than 12V and burned out within a couple days.
I ended up purchasing a couple replacements on ebay: http://www.ebay.com/itm/272213768498?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
These worked out great.
Here is a couple photos of the EATC and how you can access the bulbs.
Let me know if anyone has any questions.
Old 05-06-2016, 03:38 PM
alloro's Avatar
alloro
alloro is online now
Received 4,196 Likes on 2,432 Posts
What is the meaning to life?
Old 05-12-2016, 08:04 AM
chucky2's Avatar
chucky2
chucky2 is offline
So they just rotate toncome in or out, or is there some soldering needed?
Old 05-15-2016, 11:04 AM
alz's Avatar
alz
alz is offline
The replacement I purchased on ebay were complete with the bulbs already in the sockets. No soldering. Just a 1/8 turn in/out with a flat blade screwdriver.
Old 05-15-2016, 12:30 PM
chucky2's Avatar
chucky2
chucky2 is offline
Thx for that...one more question: How easy did the module come out? Did you have to take the trim piece around the radio and climate control out, or does the clime control module slide out by itself?
Old 05-15-2016, 02:25 PM
alz's Avatar
alz
alz is offline
Pull the trim panel around the radio and climate control. It just pulls out, no screws. Disconnect connector for 4x4 switch, if equipped. Then there are four screws that hold the climate control to the dash, remove them. Then just slide it out. The front panel has six clips holding it to the main unit. Disengage those and the board with the bulbs will be accessible.
Old 05-16-2016, 10:15 AM
chucky2's Avatar
chucky2
chucky2 is offline
Cool, thx for that, will help when I can finally get around to it!
Mikeman
09-10-2017 08:34 AM
rangerbob406
1999 to 2016 Super Duty
11-14-2015 12:56 PM
pirahnah3
04-17-2015 09:01 PM
ukexplorer
12-04-2014 02:21 PM
CBB9M
02-15-2014 02:20 PM
Quick Reply: Auto Temp panel bulbs 99 Expedition
