AM radio quit working.
Pretty sure there is only one antenna connection; there is only one antenna on the outside. So you probably have some issue with the radio itself.
AM radi quit working
Same thing happened to me today. AM stations just have static, they all worked fine yesterday. FM works fine and so do Sirius. Did you ever gets your AM stations to work again??
Ford dealer fixed it. I'm not sure what they really did. Took them a long time. First they said they replaced the am antenna base and said it was fine for a minute then the whole system crashed. They said they "jumped it" and it came back on but with no am radio. Finally she said they were going to replace the computer behind the screen. Strange thing is when I finally picked it up with the am radio working all my presets and phone were still programmed. They were all lost the first time I took it in.
Another strange thing is the daytime running lights had quit working. When I told the service consultant she told me it didn't have daytime running lights. Well now that the radio has been fixed the lights work again too.
My AM radio in my '15 502A quit working a couple of weeks ago, but I have not had it back to the dealer yet to have it diagnosed. All other functions I believe are normal, just no AM. I tune the stations I want to listen to through TuneIn or IHeart on my phone and Bluetooth them to the truck. Not as convenient but it's a workaround until I have it repaired.
7D0-01-01 *xxx xxxx xxxx Sony Sound Processor: A=enabled, 2=disabled
7D0-01-01 x*xx xxxx xxxx Reverse camera (8" screen only): 0=disabled, 2=enabled, A=enabled with obstacle detection
7D0-01-01 xx*x xxxx xxxx Stereo Extended Play: A=off, 2=20mins, 3=30mins, 4=40mins, 5=50mins, 6=60mins
7D0-01-01 xxx* xxxx xxxx CAN Steering Wheel Control Switches: A=SWMT (cursors & OK button over CAN), 9=CGEA SCCM (log missing messages), B=SWFC (i.e. has special functions)-CMCA
7D0-01-01 xxxx *xxx xxxx Aux Input & Volume **** Display: 0=Audio Only & Rotary volume, 8=Audio & Video & Rotary volume, 1=Audio Only & Horizontal volume
7D0-01-01 xxxx x*xx xxxx Aux Input Installed (AII) & Ignition Type (IT) & Speaker Fader in menu
5=AII not present & IT push button start & Fader enabled, 4=AII not present & IT key start & Fader enabled, 1=AII present & IT push button start & Fader enabled, 0=AII present & IT key start & Fader enabled, 9=AII present & IT push button start & Fader disabled, 8=AII present & IT key start & Fader disabled
2016 f150 am radio not working
Accessory protocol interface module controls lot of sync, here are a few lines of code from forscan; 7D0-01-01 *xxx xxxx xxxx Removes Sirius from audio sources (decrement your value where the asterisk is by 2; if you have an "A" make it "8", if you have "2" make it "0")
artscott61
10-31-2017 08:50 AM
Thudpucker
07-25-2008 05:39 PM
