Member 241 intro, a diesel guy
I originally posted in the BS thread before I changed my 'location' from CA to WA. I'm going to try to start fresh.
Me, I moved from CA in Jan to start a new job for Century tel. I'm originally from Albany, OR and hope to get a job transfer to Vancouver/Camas area as soon as I can. I am a medium duty diesel performance guy. Meaning, hot rodding the DT466, Cummins 8.3, Cat 3208, and Ford 6.6 & 7.8. It's great when an F700 that's able to keep up with a chipped F250. I dabble in the pickup diesels a little too, but not as much.
The Ford truck I use is a reasonably modded 67 F100.Used to be my daily driver for 8 years with manual steer, no radio, and non-power assist drums on all 4. The big six has a 274*/.518" cam, GM rockers, Offy C intake, Edelbrock 500 carb, Headdder with dual 2" & glasspax (lead sled sound), recurved Duraspark powered by MSD box and coil.
The truck has a 3G alternator conversion. KC Daylighters H4 headlight conversion with relays. Hydrobooost setup is totally amazing. Started with a Saginaw PS pump from an 81 E150. The hydro and master unit is from a 95 Astro van. I got the hoses & fittings from Summit, so I can make my own. Then, it has a disc conversion from a 75 F100, using Powerstop rotors and stock rear drum setup. All the suspension is poly bushings. Added a sway bar a few months back, which was great.
Inside is pretty basic. I took off the dash pad, and added a radio in place of the radio delete plate. I have an AC setup I got off ebay, but havent got around to that install yet. Body mods are replacement panels from an F250 I bought for $250 from an FTE member. The 2 tone parts.
A vid of my 300 with open headdder:
Plus, I got 2 vids of the 700. It's a 93 F700 with an 8.3 that has 450hp marine injectors and HX50 turbo:
http://vid249.photobucket.com/albums...0310a801e4.mp4
http://vid249.photobucket.com/albums...fe2817bf3d.mp4
I usually visit the heavy section first
Here's 1 pic of it.
http://www.pirate4x4.com/forum/attac...o-img_2884.jpg
Here's 1 pic of it.
TheLetUp
77
07-26-2014 03:12 AM
c00nhunterjoe
11-30-2008 04:05 PM
