Rusty passenger side intake manifold
So I currently have a bit of a rust issue on the passenger intake manifold and on parts of the block above it. I was wondering if there is a way to coat it with some high temp clear or something idk to contain the rust until I am able to buy a new passenger side intake manifold. It's probably fine, but hey I worry about my truck.
That exhaust manifold is like $90. Get a new one, soak the old ones bolts with your favorite penetrating oil (Kroil, PB Plaster, acetone and atf mix, etc.) for a few days and swap that sucker out. You may want to get a new set of manifold bolts too.
http://www.ebay.com/itm/7-3-Ford-Diesel-2000-2001-2002-2003-New-Exhaust-Manifold-Right-/371526783194?vxp=mtr&hash=item5680b8d0da
Sorry Jason... that's an intake manifold - not such a minor task to replace.
As for the rust converter and the body - the stuff works pretty good as long as all the heavy rust is removed. It works on just the light remnants of rust and paint over that does a good job of preventing a re-occurrence. For the bigger stuff, the guys here recommend something like Chassis Saver.
bigwin56f100
07-17-2019 08:40 AM
LLAMASvsROBOTS
29
09-13-2014 09:21 PM
JMG1
11-13-2013 03:33 AM
jmadsen
07-03-2013 08:53 AM
dpbrowne
06-08-2003 12:39 PM
