269k on a 04 6.0, in the rust belt, oil pan is needing replaced according to the tech. It looks rusty for sure. 1300+ to change it. I understand you have to lift the engine some to replace.
Engine is stock, are there any aftermarket pan's worth looking at if I'm going to replace it?
No, the engine does not have to be lifted "a little bit"; see video:
That only works if the bolts aren't rusted. All the rusted ones I've done have rusted bolts above the cradle and a bolt extractor pounded on is the only way to get them out. They can rust down to a 5-6mm head. The oil pan in the video wasn't rusted at all.
The way it was done in the video is exactly the same way I do it too. And yes, I agree with the statement about the bolt heads, which is exactly why I usually quote new bolts as well as the pan itself, so that I don't care about how badly I mangle the bolts during removal if I'm only going to discard them after. I think DTR was only doing an oil pan reseal in the video.
