Craigslist 400 teardown/rebuild
Heres a clip of the best pull on the dyno
Not the biggest numbers, but for what I have into it I am happy
355 HP @ 4800rpm
434 TQ @ 3800rpm
https://www.youtube.com/watch?v=WB0R0gS0d94
355 HP @ 4800rpm
434 TQ @ 3800rpm
Edlebrock 1406 carb with a 4 hole 1" spacer , performer intake.
Having starter problems. The first one I put on was a Summit Racing high torque job, it cranked the motor over good but never sounded right, turned out to have 11 teeth instead of 10. Next was a PMGR starter and it worked good for a week, then it wouldn't crank over on a hot restart, then failure. Now I got a PMGR unit from O'reilly and it's doing the same thing, starts cold but won't start hot.
What kind of compression are you running? And, what ignition system? What initial lead? And how many miles on the engine
I ask because it sounds like you have a lot of compression, lots of initial lead, a very tight engine, and your ignition system doesn't retard the spark while cranking.
Edit: I see that you say you have 9.3:1. Are you sure?
Check to see if your DS-II box has the wire sequence as shown on this thread. It is entirely possible that your box isn't retarding the timing. My Motorcraft box, the one shown in that thread, doesn't and the no-name does.
I'll let you know
I think you can test it on the truck. As you can see here (Start, Ignition, & Carb Circuits - ???Gary's Garagemahal), it is the red/light blue wire from the stater relay/solenoid that triggers the box to retard. If you start the truck and then pull the wire off the starter relay/solenoid you can turn the key to the Start position w/o engaging the starter. But, that should retard the timing, which will slow the engine. If it doesn't slow the engine then it didn't retard the timing.
Bradslab
06-12-2013 05:05 PM
willyg79
11-19-2006 06:52 PM
