1951 F4 Coleman AWD....let the games begin
Old 04-09-2016, 02:40 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
The other day we went out to the farm and drug the F4 home. It has been sitting in front of the "new to us" work shop for the last week. Today was the day we got it inside and it presented some problems as you will see.
We pulled the rear tires and rolled it in with a cherry picker. After we had let the rear down of course. Had to pull some trim off the garage door opening to get an extra half inch. We had planned on replacing the front wheels and tires with something shorter but the lug nuts laughed at our attempts. That will have to be addressed in the future.
Old 04-09-2016, 03:55 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
My back hurts just looking at your pics, and knowing it mighta been me. I suspect your initial go at the front nuts was to allow "roll around" mounting of a pair of your 16" Budd 47210s. Tires probably 5" shorter than the 7.50-20s, so you'd have gained 2.5" at the door frame. Glad to see it indoors and safe. School is now in session.
Did you get the transfer case shifter freed up? Stu
Old 04-09-2016, 04:32 PM
thundersnow70
Correct Stu. We should have check the torque on the F4 lugs before we removed the tire from the F2 MH. We only removed one as we planned on using that homemade 15 inch I picked up from Rory when you stopped that summer. I think I'm gonna make another 15 inch and just keep them on until I get the clearance situation figured out. I will say it rolled easier than I thought it would.
Old 04-09-2016, 04:38 PM
truckdog62563
May have to mount them backwards to clear drums. Stu
Old 04-13-2016, 10:32 AM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Nice truck !!! But for a half inch you couldn't just let some air out of the tires? Sorry
Old 04-15-2016, 01:43 PM
thundersnow70
We pulled the cores and the old bias tires stood tall. They are still standing tall. If i knew it was going to be that tight I would have pulled the cores last year. I can't wait to dismount them. Maybe I will use a sawzall.
Old 04-15-2016, 08:29 PM
thundersnow70
Progress
For some reason this small plate was poorly welded onto the passenger side front Coleman hub. I figured it was cracked or had a hole under it but when I removed it all was good. Now I'm thinking it may have been an attempt to balance the hub? Thoughts Chuck?
Old 04-15-2016, 09:30 PM
CHUCK48-50's Avatar
CHUCK48-50
CHUCK48-50 is offline
That's a new one on me. If it wasn't an attempt to balance something, I'm sure it threw it way out of balance! It will be interesting to see what you find when you take it apart.
Chuck
Old 04-16-2016, 05:23 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,833 Likes on 1,833 Posts
Wow
That's going to be one tough truck!!
Good luck
Bobby
Old 04-28-2016, 09:38 PM
thundersnow70
Making progress. Had my buddy stop by with his service truck to get the front wheels off. His impact had a hard time with a couple lug nuts. I asked him how many ft. pounds it was rated for. He said 500! That explained why I could not budge them.
Old 04-28-2016, 09:51 PM
truckdog62563
Hope that front axle doesn't hurt your jack. Stu
Old 04-28-2016, 10:12 PM
Jules The Great's Avatar
Jules The Great
Jules The Great is offline
Maybe the plate was welded on to protect the drain plug/gimble pivot? Are you planning to completely disassemble and rebuild the front axle?
Old 04-28-2016, 10:59 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
Holy crap that axle is a monster.
Maybe you should air bag the truck to lower it down some...
Old 04-29-2016, 02:24 AM
casper1999's Avatar
casper1999
casper1999 is offline
That is a serious axle!!!! Coleman didn't mess around did they..
Old 04-29-2016, 04:57 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Folks, that there is the very definition of 'old iron'. Zounds!
Quick Reply: 1951 F4 Coleman AWD....let the games begin
