1951 F4 Coleman AWD....let the games begin
Old 04-29-2016, 09:44 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
Originally Posted by Jules The Great
Maybe the plate was welded on to protect the drain plug/gimble pivot? Are you planning to completely disassemble and rebuild the front axle?
The plate was covering nothing. I have not cleaned that spot up yet bet it does not appear to be cracked or damage. Time will tell.
Old 04-29-2016, 09:48 PM
thundersnow70
Originally Posted by jmadsen
Holy crap that axle is a monster.
Maybe you should air bag the truck to lower it down some...
Probably wont bag it Josh, just a SBC and auto trans. Maybe switch the Coleman front axle out for a spare closed knuckle Dana 44 I have.
Old 05-01-2016, 08:19 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Wow, Coleman really believed in heavy duty front hubs! Did they use the same parts up through F-8 or something?
Old 05-01-2016, 08:44 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
Here's the ad showing the application for F-2 through F-7. I know the five lug hubs would have been F-2 through F-6, but don't know if the axle itself was same through F-7. If Mark doesn't know, I'm sure Chuck will. Wonder why the ad doesn't include the F-6? Stu
Edit - Here's the 1951 ad I was looking for. It lists all the models. Stu
Old 05-02-2016, 09:40 PM
thundersnow70
Heck if I know Stu, I did notice the ad for the monkey face omits the F6 but the ad for the 51 shows F6. Its my guess that the stub shafts and everything outboard are the same on my F4 and Chucks Big Job. With the exception of the dome that has the studs in it. It would also seem that any F1,2 or 3 would have to have a smaller hub just due to a smaller tire being run on the truck. I will wait for Chuck to set me straight! Enough assuming for now.
Old 05-04-2016, 09:51 PM
thundersnow70
Houston....we have a problem
The good news is we found the odd noise when the wheel turns. Its the power yoke flopping around because the pins/holes are worn out. Plus I dont think all this gear lube is suppose to be in the hub. I believe the inner seal needs replaced along with a new "seal riding surface" on the axle shaft. We couldn't get the power yoke pins out but we didnt try really hard. Figured we would stop before it got worse!
Old 05-05-2016, 02:31 AM
truckdog62563
Mark - did you ever get a service manual for the axle from Chuck or Craig? Sure would make life easier. Or does that later Marmon-Coleman manual you bought explain things? Stu
Old 05-05-2016, 05:35 AM
thundersnow70
I haven't got the manual from Chuck yet. I'm sure he is busy with bigger things than making me a copy. The Marmon/Coleman manual is pretty close. The general design is the same. We need to get the two pins out and remove the power yoke. Then remove those eight bolts on that plate to get to the rest. Disassemble with out a manual doesn't bother nearly as much as how we are going to repair that slop. I imagine if we throw enough money at it all things are fixable.
Old 05-14-2016, 10:04 PM
thundersnow70
Well, it only took three nights to remove two plugs and two pins. One plug came out easy and the other was a pita. The second one broke and stripped. Then I drilled it, then I tried a bolt extractor. That didn't work. Then I used a roto tool to finish it off. That hole will have to be addressed at a later date.
The next step is to remove the pins holding the power yoke to the compensating ring. There is ALOT of play in there. I am NOT looking forward to what I will find.
Old 05-15-2016, 02:44 PM
truckdog62563
So far, nothing made of unobtainium seems beyond saving. Hopefully bearings and seals are all that'll be needed. And keep your magic dust handy when you pull the drums. Stu
Old 07-03-2018, 08:30 AM
thundersnow70
Well, it's only been a little over two years since the last post on this thread. It's taken me that long to source a couple wheel bearings. The spindle bearings are sourced and the axle seals ordered. Got my parts washer up and running so now everything can be cleaned and ready for assembly. As soon as I get a new photobucket account I will post some pictures. Better late than never.
Old 07-03-2018, 09:01 AM
truckdog62563
I’ve been texting with Mark over the past couple of years and following along as he searched for these bearings. It was quite an ordeal for him to find them. The list price for each set here in the US was multiple thousands of dollars. Simply cost prohibitive. Mark tracked them down from China, for a small fraction of the cost, and turns out they are real Timkens. It’s great to see this rarest of rare trucks being saved. Mark deserves a huge attaboy. Stu
  #28
Old 07-03-2018, 05:11 PM
casper1999's Avatar
casper1999
casper1999 is offline
Major score Mark, nice going!!!! Once again persistence pays off in a big way. Good luck going forward.
  #29
Old 07-03-2018, 06:15 PM
nsboyd1210's Avatar
nsboyd1210
nsboyd1210 is offline
Mark,
What a fun and interesting project!
My truck did not fit in my garage due to the same reason. I ended up opening up my door from 7' tall to 8'. In looking at your pictures I wonder if you have room to do that. More overall cost though.
Stu you were not kidding about the price of the bearings. They are $5,736.63 apiece on Amazon and Prime at that! Procuring parts can be a challenge for a number of different reasons.
I'll be checking in on occasion with interest to see your progress.
Nelson
  #30
Old 07-03-2018, 07:15 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
Quick Reply: 1951 F4 Coleman AWD....let the games begin
