78-79 bronco spare tire carrier on 73-79 f150?
My truck currently has no place to keep a spare other than sitting in the bed. No under bed mount or anything. This is made more complicated because I have 37" tires.
Would using a rear spare carrier from a bronco work? If not, any recommendations for how to securely mount a large spare?
A bed mounted spare tire bracket and or a under the rear tank could be done easy enough.
A 78/79 bronco spare tire bracket could be mounted to a bed, but I think the 37" tire would be to much to hang off it. Especially when you swung it open to drop the tail gate, might tweak a bed side? That area of a Bronco looks to be reinforced.
What about a spare tire mount that is made to mount and swing off the rear bumper?
Proto Fab Products Page See #321?
http://www.protofab4x4.com/products.php?ID=00&ID2=74
There is another spare tire mount and location option. Ford did offer a spare tire mount that mounted to the front bumper and grille of the trucks. Most commonly found on 250 camper specials, but can be just as easily mounted on any other 1/2, 3/4, and 1 ton truck. Although it may be a little harder to find. Check Craigslist, eBay, any other classified ad sited and paper, and also check salvage yards, swap meets and even flea markets. Never know what you'll find at those places.
There is another spare tire mount and location option. Ford offered a spare tire mount that mounted to the front bumper and grille of the trucks.
Most commonly found on F250 camper specials, but can be just as easily mounted on any other 1/2, 3/4, and 1 ton truck.
A similar version was (may still be) available from R/V dealers.
1974/77 F100/350, also fits 1964/73 F100/350, some 1978 F100/350's, because...
C4TZ-17757-C Painted & C4TZ-17757-D Chrome .. Front Bumpers: 1964/77 F100/350; 1978 F100/350 before serial number AG0,001.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
A "Reese" is for a a brand name and is a hitch that normally goes from one frame rail to the other frame rail and is either bolted or weld mounted on the bottom and is a drop style hitch that has a 2" receiver tube out the back. Alot of times that style (cross tube) of hitch interferes with the OEM spare tire set up. Also been known to cause problems drooping the rear tank.
https://www.northerntool.com/shop/to...SABEgLFxvD_BwE
Sometime you have to move the hitch mount brackets further back or closer to the end of the frame rails.
SwampFox112
19
01-30-2016 01:47 PM
