Real oil pressure gauge
I have installed a real oil pressure gauge on several trucks and I have been considering installing a real gauge on my 2015 F150.
Let me know what you think.
The only concern I have is how much information does the computer obtain from the OEM sensor and how an extra hose to the aftermarket
pressure sensor would effect the computer.
I would hate to set off a trouble code.
The factory "sensor" is nothing but a pressure switch. Over 5 PSI(IIRC) the switch closes and the low pressure light/gauge shows normal.
I don't really understand the benefit of a pressure gauge, but if done properly it shouldn't affect the computer any. Of course you'll be on the hook for a >$10,000 engine replacement if your plumbing or hardware fails and leaks out all your oil and you're not paying attention to the gauge.
There is ZERO chance I'd be doing this to a brand new truck. Chance of failure may be very low, but the odds of you being on the hook for an oil-related failure unmodified are virtually nonexistant unless you neglect your truck.
I'm quite confident in my plumbing skills, especially since I'd probably use an electric gauge and that means there'd be no tube. Remove the existing sender, install a tee, and then re-install the original sender and install the new one. The computer would never know since the pressure would trip the switch just like before.
But, I don't see the need for an oil pressure gauge - at least while the truck is under warranty.
But at the end of the day I don't think it's worth the hassle to get. I've never heard of anyone saving an engine because of an oil pressure gauge. Most of the time low pressure is caused by worn bearings anyway, and that's almost impossible to happen during the factory warranty period.
Don't get me wrong...I really wish there was a real factory gauge. One of the things I liked the best about the Ram I test drove was a real digital gauge for coolant temp, oil temp, and oil pressure.
If I had my choice between a on/off fake oil pressure gage and a nice big red no oil pressure light I would pick the light. But would prefer a real gage and a light.
Ford did use real electrical gages back in the old days,, but people were complaining that the gage dropped at idle.. So the fix was to install the on off pressure switch and a resistor so the gage showed halfway or 0. That than became what we have now.
Jonnys.1991
08-11-2015 01:56 PM
liberty_mi
11-17-2003 02:54 PM
