Coolant in spark plug well #8?
I have a 2006 F250 5.4L. I was getting a noticeable misfire after not driving the truck for a while.
Mode 6 revealed that cylinder #8 was misfiring.
I took off the coil/boot and there was coolant on the tip of the boot and some at the bottom of the spark plug well.
I cleaned everything up and put everything back together and that took care of that problem when I started the car. I also stuck a wad of paper towel by the intake manifold nearest spark plug number 8 and tightened the manifold bolts down a little. Some of them were not as tight as others.
I went back today and started the vehicle and it has the same problem again!
I took a look at the paper towel and it was totally dry! There is no coolant around the top of the spark plug well - only in the bottom of it. Where is this coolant even coming from? There are no coolant lines near cylinder #8. Is this a head gasket leak? I have taken a look at the head gasket and that doesn't seem possible since the head gasket does not seal around the spark plug well at all as far as I can tell.
Anyone have any ideas?
Its sounds like a cracked intake manifold.
Take a look at this: 2004 F250 Intake Manifold Replacement
Hey, I think looking around the cowl was a good idea. I looked today and it rained today too but there was no water under the cowl and there was no water on the COP.
I replaced took the COP off and there was no water down in the well. I don't know why it was misfiring. I replaced the COP and that solved the problem. I still don't know where the water came from originally though. Maybe it was from snow melt and that got around the cowl somehow? Don't really know.
