79 F150 4x4 Sway Bar Bushings
If your truck has the factory sway bar and not aftermarket, according to the Ford parts catalog the bushings are not replaceable. They are a part of the link between the bar and the truck's frame. The whole link needs to be replaced.
Link assy., front stabalizer bar
Fits '78-up F150 regular cab w/ 4WD Quan. required 2
D8TZ-5K483-A
I was only able to locate 2, well actually 3, one is in Puerto Rico.
Lochen Ford, Newburg, WI has 2 (262) 675-6565
D8TZ-5K483-A
When I put my lift on I bought extended sway bar links and I had to burn the rubber bushings out to replace with polyurethane bushings. Beware that when removing the nuts off the bottom of the links that they may twist off the end of the link and you would then have to buy a new one anyway. Sometimes the threads get messed up from running over stuff. I got all my bushings from bronco graveyard about 12 years ago.
andym
09-09-2004 07:29 PM
