Service Engine Soon Light - Ford Truck Enthusiasts Forums
Old 08-13-2003, 12:59 AM
John Hancock John Hancock is offline
John Hancock is starting off with a positive reputation.
The Service Engine Soon light has been on for a couple of weeks now. I change my own oil/filter(s) and do most maintance.
Is there any way to get the light to go off without taking it to a dealership?
'99 F-250 light duty, 4X4, super cab, 5.4ltr
Old 08-13-2003, 02:00 AM
gkbid gkbid is offline
gkbid is starting off with a positive reputation.
Take it to Advance Auto, Auto Zone, or O'Rielly's...they'll all read the codes for free. It will give you a good indication of what caused the "CEL" and you'll find this forum very helpful with regard to how to correct it.
Old 08-13-2003, 11:40 PM
Thanks for the info...I always forget about Auto Zone's service. Thanks again
Old 08-16-2003, 05:50 PM
tonypal22 tonypal22 is offline
tonypal22 is starting off with a positive reputation.
I am having the same problem. I change my own oil, but I was told if the engine is not reset somehow, this light comes on after a certain mileage between resetting. If you find out anyhting I would appreciate the info, and I will do the same- Thanks
Old 08-19-2003, 12:05 PM
MrBSS MrBSS is offline
MrBSS is starting off with a positive reputation.
While some vehicles do indicate maintenance services, I believe the Ford "Service Engine Soon" light only comes on if some sort of trouble is indicated. You can reset it by disconnecting the battery completely for a few minutes, but it will probably just come back on though you might lose a trouble code that you would later wish you had. Your truck may also run poorly for a while afterward just because the computer has to relearn some of its parameters.
You should get it read as soon as possible. Especially since you can get it free--they can't make you buy the repair-- and then you can make a better decision on what to do (if anything). Incidentally, in most places, you will automatically fail the emission test if that light is lit, or fails to light and then go off upon start up.
Old 03-10-2008, 08:11 PM
exploderfan exploderfan is offline
exploderfan is starting off with a positive reputation.
I just had this problem with my 99 F250. Twice now in fact.
I took it to dealer to find the trouble and asked the same as above poster. Does this mean service is due or is it a problem. he said it indicates problems, they stopped using the light a few years back to indicate service intervals. My trouble first time was EGR valve and ports in intake were fouled with oil and they had to be cleaned. Less than a week later the light is back on and tomorrow I go back for a hookup to computer to see what coded this time.
Mike
Old 03-17-2008, 11:34 AM
whimsey whimsey is offline
whimsey is starting off with a positive reputation.
The dealer charges over $100 just to read the codes. I went to Walmart and purchased an INNOVA code reader for less than a hundred bucks. This way when I go to a mechanic or dealer at least I know what's wrong and what's BS. It's paid for itself already.
Whimsey
Old 03-17-2008, 11:38 AM
well, I went and they now had a different code stored. It pointed to EGR valve. Replaced it and have not, so far, had any problems with it.
I agree that the cost to just hook up and read codes is abusive, and will probably do the same, go buy myself one.
Mike
Old 03-17-2008, 12:01 PM
BillC's Avatar
BillC BillC is offline
BillC is gaining momentum as a positive member of FTE.
Even if you go buy a code reader, the mechanic or dealer is still going to diagnose your vehicle. Who would you get mad at if you took your truck in and said it was code PXXXX now change this part, and it doesn't fix it.
Old 03-17-2008, 12:08 PM
not what I would do in any case. I would at least know when they say it's code yyyy and I know the reader came back with xxxx. That way I could decide to continue with that dealer or move on to another. Also, I repair a lot of my own troubles and this would help in that area as well.
Mike
Old 03-17-2008, 01:09 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Don't be surprised when that same fault comes back. EGR valve failures are quite rare and the odds are good that the problem is elsewhere.
Steve
Old 03-17-2008, 01:14 PM
I hope not. I just bought this truck and was hoping for a decent time with it. They already tore off the intake and cleaned all the ports and installed new gaskets. Now the valve. What else would trigger a code that specifies the EGR valve?
Mike
Old 03-17-2008, 03:06 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Quote:
Mike
A bad DPFE sensor(EGR flow).
JL
Old 11-06-2014, 04:42 PM
Robert Clapper Robert Clapper is offline
Robert Clapper is starting off with a positive reputation.
CHT sensor
My "service engine soon" warning light came on today and Auto Zone read the codes to indicate a failed CHT sensor. Coolant was low but temp gauge has never read hot. Should I try to replace it by removing the alternator or take it to the Ford shop? 2000 F250, 5.4. What might they charge?
Old 11-06-2014, 07:26 PM
Post the exact fault code. Do NOT rely on the drone at AutoZone for a diagnosis.
service engine soon light Scott Scheele 1997 - 2003 F150 7 01-11-2016 10:32 PM
Service Engine Soon Light - Rough Idle RUMO 1999 - 2003 7.3L Power Stroke Diesel 15 04-22-2008 03:52 AM
Service Engine Soon Light bo780 1999 - 2003 7.3L Power Stroke Diesel 17 02-19-2007 07:03 PM
Can the transmission set off the "service engine soon light?" quick35th 1997-2006 Expedition & Navigator 36 08-15-2006 01:39 PM
Service Engine Soon light is On???? DRIVIN13 Electrical Systems/Wiring 1 07-20-2004 10:56 AM
Tags
07, 2000, 2003, autozone, engine, f150, f250, f350, ford, light, resetting, service, soon, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
