Broke down last night...what could it be?
Coming home last night, hit a pothole in the road and suddenly the truck seems to go into limp mode...lost all power to the aux fuse box (VHF/UHF shut down, GPS and phone cradle power died, dash cam shut down, GlowShift gauges shut down).
Initially I thought the aux fuse box relay died, but the stereo was out, and all gauges but the RPM were flat...turn signal was dim, air bag/oil pressure lights were on, blower motor went from high to barely working.
SCT was still up and I see 9volts...but no battery light on the dash!?
Made it off the road but left the engine running, checked to see if maybe a battery cable was loose...both were fine.
Tried limping it to Pep Boys while the wife called ahead to check to see if they could test the alternator on the engine and if they had one in stock.
Every time the turn signal lit, the engine strained. As we got within a mile of the shop, I couldn't accelerate from a stop and was able to barely get it off the road at an interstate on ramp. Engine was running, SCT showed 7.6volts. At 7 volts it started chugging bad and I had to shut it down.
AAA was able to get it to the shop before they closed. A jump starter was able to get it running long enough to get it into a bay. They opened at 7:30 and I'm first on the list for work.
Could it be anything other than the alternator? Why didn't I get a battery light if the alt died?
Rob, sorry to hear of the trouble.
Not sure if the V10s have it, but on the 7.3 there's a power junction block on top of the driver side wheel well, about 18" in front of the firewall. I've seen some pictures of those corroded so bad that current flow stopped...
I wonder if the pothole jarring could have broken a lug off of a cable or terminal. Good luck.
Maybe, because you have a GAUGE (meter)??
Uh,
1...you still get the battery light once the volts drop below a certain level
2...the gauges on our rigs are three stage - high, normal, and low.
None of the gauges on a 2000 other than fuel, speed, and RPMs report actual levels, only one of three stages.
AND...as I stated, it was normal, then nothing...so exactly how would the gauge have helped ahead of time? And let's not forget, the SCT reported 13v before the alt let loose.
Maybe leave out the next time?
Uh,
Yes they are BUT did it go to low ?? Was JUST funning with you on the question. (is drink ok ??)
OH by the way, When mine went out pulling as I was moving. It crapped out with no warning (that I noticed) & left me on the side of the road with a 20' loaded trailer. Luckily was only 2 miles to run get another battery to get it home. SO in conclusion, I'd have to say Worthless gauge & light on the 2000's.
I usually sit around 13.8 measured by the SCT. The UHF/VHF reads voltage every time you start it, and it usually reports 13.9, so I trust the SCT is fairly accurate.
On the SCT I monitor Coolant temp, Trans temp, Load, Battery Voltage, Intake Air Temp, and Vehicle Speed.
VHF/UHF (truck was just starting, so 12.8 would be normal with everything turning on at the same time)
SCT:
GlowShift gauges:
SCT:
GlowShift gauges:
Interesting, with my charging system working properly I don't see less than 13.8 even at start up.
What amperage rating is the alternator? Did you get the tow/camper package version? I have been running a Motorcraft reman for the last couple years. Warranty period just ended in November.
Which battery are you running and what is the CCA rating?
I had the same thing happen to me one time with my old 03 Ex. All the gauges died, radio shut off, no battery light came on, and it actually died on me when I was pulling off the interstate. It took all of maybe 2 min for it to die after the gauges went down. I don't trust that battery light at all.
