distributor wiring diagram 94 4,9L - Ford Truck Enthusiasts Forums
Old 01-29-2002, 08:21 AM
finbog finbog is offline
finbog is starting off with a positive reputation.
Post distributor wiring diagram 94 4,9L
I have the Hayes manual for my truck 1994 f150 4x4, 4.9L, but when I check the wiring diagram for my distibutor it does not match what is under the hood, the firing order is entirely different. truck starts great, but tends to stumble on the odd occasion, specialy when it is half warmed up, any one out there with a similar problem ?
Old 01-29-2002, 03:38 PM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
I can't say anything about the wiring, though I did read recently there were two different firing orders for the inlines. (?)
But besides checking the timing for your stumble, and typical tune-up pieces, I can't say enough good things about the EGR restrictor plate I made for my 1993 4.9. I installed it last weekend, and as of driving it around even this morning I am still amazed at how much more smoothly it runs, idels and doesn't hesitate from a stop.
Think about making one.
Plus, you might want to look at the
http://www.ford-trucks.com/dcforum/DCForumID39/2834.html
post.
Old 01-29-2002, 07:01 PM
mikey67156 mikey67156 is offline
mikey67156 is starting off with a positive reputation.
Does anyone know which one is the tach wire on a 95 f-150?`
Old 01-30-2002, 07:08 PM
madman666's Avatar
madman666 madman666 is offline
madman666 is starting off with a positive reputation.
Are trying to hook up a tach and wanting to know which wire at the coil to hook it up to?
If you are its the negative one, the wire closest to the intake, think its red with a green stripe, if my memory serves me correct.
Old 01-30-2002, 07:49 PM
Green_Monster Green_Monster is offline
Green_Monster is starting off with a positive reputation.
1994 E150 4.9L Vacuum hose diagram. rwbrooks50 1968-2013 Full Size Vans 8 02-12-2017 07:39 AM
1986 F150 4.9L Wiring Diagram? ooxneozoo 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-19-2014 05:14 PM
Distribution Box diagram - 94 E250 danyl01967 1968-2013 Full Size Vans 2 07-25-2011 08:28 PM
wiring diagram for a 4.9? l BlAcK l Ford Inline Six, 200, 250, 4.9L / 300 6 05-13-2011 06:42 PM
Fuel Pump Possibly not Working 1995 4.9L F150 Nehmo 1987 - 1996 F150 & Larger F-Series Trucks 45 02-11-2011 04:01 PM
Tags
150, 1986, 1987, 1994, 49l, 94, diagram, distributor, f150, ford, negative, v6, wire, wireing, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
