Ready to order 350
Ready to order 350
After doing the research and a lot of discussion we have decided to sell our '13 EcoBoostwith only 22K miles........ for a new 350.......need the extra payload no matter how I sliced it.
Going King Ranch with short box and SRW. Couple quick questions before I place the order if you all would mind firing in:
1. Does anyone use the 4 aux toggles and if so for what?
2. Why a second alt?
3. Snow plow kit to level it out even if I'm not going to plow?
4. Camper package and fifth wheel prep to cover all the towing bases?
5. Aux cab heat...is the cab really that much bigger than my 2002 was?
Anything I should consider to set it up so I can tow as much as possible with SRW?
Thanks for the input guys.
2 - To handle high-current loads, like a plow.
3 - Camper package add's the same front springs, I believe.
4 - 5th wheel prep is a must - having the hardware mounted to the frame, and through the box so cleanly, is worth it...
5 - Aux heat is less for the extra space, and more to get you heat faster at start up... it takes the diesel a while to build heat; the aux heater gets the windshield defrosted, and the cab comfortable before the engine's up to temp...
I came from a '13 F150 5.0 to a 15' F350 6.7 - no comparison for towing...
The heavier truck just felt far more comfortable with the camper behind it; lots of power - just got back from a 3500 mile trip from Toronto, Canada to Orlando, FLA and back - even through the mountains of West Virginia, (and I-77 goes up and down a lot...) truck never blinked with 8000# behind it.
Think I read that the 2017 "order banks" are open on the 13th of this month. Not sure if that means they're open for orders after that, or what.
Thanks to all for the feedback. Have it figured out except for the color. Wooohoooo!
On the one I just ordered, I got the upfitter switches, 5th wheel/gooseneck prep kit and camper package. Dealer told me not to get the snow plow package if you are not going to use it for a plow because it actually makes the front end sit up a little higher than the rear since it is a stiffer front end. The camper package gets you a sway bar as well in the rear.
To me, these items were a no brainer, especially the 5th wheel/gooseneck prep kit as it is only $370 from the factory whereas it would cost you 3 times that much to have it done after market. Plus, I really like the clean look coming from the factory.
I got the 6.2 gas so I cannot talk to the other items you mentioned.
This is what I was told and what I observed on the lot before I ordered. Everything below is related to SRW SB 4 diesel F350.
1. Snow plow gives truck plow verification and adds a heavy duty alternator which is needed (or dual alternators) for aux cabin heat. Could not tell if front springs are different but it was the least expensive way to get what is needed for extra heat.
2. All trucks I looked at with 5th wheel prep had rear sway bars and none had camper package.
So....I ordered 5th wheel prep and plow package and believe I got the best suspension possible for towing. If I'm wrong I guess I'll need to change it. It's only money.....
