1951 F1 w/ 2008 CV interceptor power plant
Old 04-24-2016, 04:23 PM
jonf's Avatar
jonf
jonf is offline
I see that the cross member for the transmission has the center cut out and that may explain why you had to fix the frame. My recommendation is that you make a drop out cross member to connect the two ends.
Also, think about offsetting the engine and trans towards the passenger side to get more header clearance for the steering. Moving those an inch or two will save you a lot of grief later.
  #32
Old 04-24-2016, 07:41 PM
CarlRay's Avatar
CarlRay
CarlRay is offline
Originally Posted by drptop70ss
Looks good but I would inspect that Johnny law Helix junk very closely before using it, myself I would toss it. Lots of posts on the net with junk welds and control arms welded out of shape. Do a search on Helix, Johnny law, and the other Hoffman Group divisions of Chinese parts. You may want to reconsider.
Now you Jumpin weeks later LOL
I have looked very closely at all of it and to my untrained eye all the welds look exceptional.
Moving forward .........
  #33
Old 04-24-2016, 07:46 PM
CarlRay's Avatar
CarlRay
CarlRay is offline
That could be but I've seen a lot of them like that? Believe me there will be ample bracing when I'm done. The half that's on the driver side I need for my under the floor brake master but the other side will be determined once I get my crossmember in that I took out of the Crown Vic. Thanks for the help And the tip about the offset I'll be paying close attention as I do my mock up.
  #34
Old 05-06-2016, 06:51 PM
mustangmike6996's Avatar
mustangmike6996
mustangmike6996 is offline
I put a 32V 99 Cobra engine in my F1 with BBK longtube headers. It is a tight fit but it clears the steering shaft. Took a bit of clearancing to get it right.
  #35
Old 05-27-2016, 12:23 PM
CarlRay's Avatar
CarlRay
CarlRay is offline
Yes I still have that to tackle. What did you do about your fuel tank?
Did you change over to a carb or use the FI? My brain hearts trying to figure out the fuel delivery and sending unit to include the vapor recovery and rank pressure. Not sure how to go about this. I have a mid year mustang tank I was going to use in the back of the frame.
Some update pics.
  #36
Old 05-27-2016, 12:28 PM
CarlRay's Avatar
CarlRay
CarlRay is offline
Was able to make the CV sway bar work
  #37
Old 05-28-2016, 11:01 PM
CarlRay's Avatar
CarlRay
CarlRay is offline
No alterations to the pan
  #38
Old 05-29-2016, 07:57 AM
mike.rogers's Avatar
mike.rogers
mike.rogers is offline
looking good
  #39
Old 06-11-2016, 07:04 PM
CarlRay's Avatar
CarlRay
CarlRay is offline
Thanks Mike!
A few more pics of progress albeit going slower of late.
Had to get the driveline cut.
  #40
Old 08-10-2016, 02:02 PM
CarlRay's Avatar
CarlRay
CarlRay is offline
  #41
Old 10-24-2016, 10:34 PM
CarlRay's Avatar
CarlRay
CarlRay is offline
  #42
Old 11-10-2016, 09:23 PM
mustangmike6996
Progress looks great so far!
  #43
Old 11-11-2016, 05:38 AM
avf100's Avatar
avf100
avf100 is online now
How wide is the rear axle? It looks like it is going to be to wide.
  #44
Old 11-11-2016, 11:59 PM
Oz52F1's Avatar
Oz52F1
Oz52F1 is offline
I'm t 100% sure about how securely the rear end is mounted, but, your work is absolutely A-ONE !!!!!
Looks awesome!
  #45
Old 12-11-2016, 09:59 AM
nathankershaw's Avatar
nathankershaw
nathankershaw is offline
Great looking project!
What an improvement over the previous work.
Well done.
Quick Reply: 1951 F1 w/ 2008 CV interceptor power plant
