Bumper mounted light bar questions.
Originally Posted by auburngrad
I used their wiring to run to the upfitter switches.
I haven't had any issues in mount strength. I have heard that the black XL grill is not as beefy on the backside, but have not seen for myself. I drive mostly paved but some gravel forest service roads and dirt farm roads. I had one light that had a loose connection at the light for the wiring, but RC was easy to work with for warranty replacement.
I've got the 20" rough country in the front bumper. Good light output and was simple to install with their bracket. I fab plenty of stuff but if quality bolt on stuff is available, I'll save the time and buy it. I kept the RC relay and used the upfitter to trigger it. I have another relay wired in so it will work with the high beams. I'm happy with the extra light output.
high beams
high beams and 20" RC lightbar
high beams
Looks killer. I drive a lot of paved but also swamp logging roads and lime rock road that's either like a washboard or full of huge holes. Gotta love central fl swamp living. One concern is there are times I'm in deep water that the lower mounted light would go for a swim.
#30
I opted for roof mount personally. Considering GA is iffy on light bars for on road use no matter the mounting height. Mine is for "off-road use" or when no one is around lol.
Best light output I could get.
Its mounted approx. 6 inches behind the top of the windshield to help elimimate hood glare.
Low beams only.
Low beam with the light bar.
In the last pictures, the furthest Street sign you can see is about 1/4 mile away. Camera does it no justice but you can see 1/4 mile easy clear as day.
Low beams only.
