66 Ford F100 wiring connectors
Old 04-03-2016, 02:24 PM
jasindude1's Avatar
jasindude1
jasindude1 is offline
I am rewiring a 66 F100, i have all the wiring kits I need, but am needing to rewire the master cylinder wires, the 2 wires on the pins for the brake lights. So heres the deal, you know the little connector jacket/boot thats on the end, i cannot for the life of me find that kind of connector or similar to use, does anyone know the name of that type of connector? I spend an hour on google looking at connector end images and havent come across it at all. So if you know the name of this connector and where I can buy them I would appreciate it, i took the wires to autozone and they pointed me to the wire connectors which none of the would "snap" on like these boots do. thanks for your help
Old 04-03-2016, 03:34 PM
wollow007's Avatar
wollow007
wollow007 is offline
Just completed wiring mine today, taken me ages lol.
I soldered my cables and then screwed them down. Works wonders.
I'm in the UK, so had to alter the brake cabling a little, I used the American Autowire kit. Had a couple of bits of information missing, but I managed to work it all out. Very good kit. Word of advise, when you crimp solder the connections also
Old 04-03-2016, 04:07 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
Are you talking about the ones that are at 90 degree angle ? Maybe you can splice these into your harness.
Ford - Ford Brake Light Switch Wire - 17 Long - Switch Extension Wire - Use With Power Brakes - Ford | B5A-14475-A - Macs Auto Parts
Old 04-03-2016, 06:36 PM
markeyd's Avatar
markeyd
markeyd is offline
I did this today with Dorman part number 85432. Bullet terminals, female .157"
Bought them because they look like they'd work, guy at store confirmed that's the size, and they were a perfect fit. I crimped them on the ends of the wires, and snapped them right onto the terminals of the brake light switch. Not an OEM look, but very functional.
Old 04-03-2016, 07:43 PM
IICAP's Avatar
IICAP
IICAP is offline
Bullet connector is correct description, but finding the in a 90 degree version for an original look is difficult. As markeyd mention size, yes they come in different diameters.
Old 04-04-2016, 08:48 PM
markeyd's Avatar
markeyd
markeyd is offline
lmc truck has the exact connector:They call it socket stop lamp switch part# 47-0671
Truck Parts and Truck Accessories
37 Ford guy
15
11-23-2011 01:20 AM
Fordzilla80
22
10-06-2011 12:17 PM
Almost_A_Merc
05-01-2005 11:49 AM
nick65f100
12-17-2004 06:47 PM
IAv10
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-24-2004 09:58 AM
Quick Reply: 66 Ford F100 wiring connectors
