Shaking, loss of power - what could it be?
I have a 2000 Excursion 7.3, 6 position tune, and exhaust as far as mods (on truck when bought). Last couple of weeks I get no power while on the throttle, foot on the gas and the whole truck shakes at higher speeds - 40mph and above. At first it wouldn't go above 60 or so, would hit the gas and Rpms would just stop not be able to generate any further power. Changed the IPR, ICP, and CPS. I still get the high/low range ICP codes, P1280, P1281. First night the IPR was changed I got it up to 90mph and thought it was all solved but got a little shake right at the top and I let off the gas. Next day back to square one and has seemed to get progressively worse, almost wasn't able to make it up a hill by my house not even going 20mph, but it's like intermittent. I have a scan tool, here is at idle and at around 60mph - what do you guys think could be the issue. Thank you.
At ~60mph
At ~60mph
Hmm, interesting get no codes - I'll check the pid more closely on the scan tool and see what's up with it. I thought there was no MAF but a MAP sensor - not sure if the pid is the same on the scan tool, have to check tomorrow. Ty for the suggestion
Haven't drained the filter of any potential water (had the truck 2 months) - I'll check to see if any water comes out. Thanks Jim
Any dead sensors should trigger a code. Any sensors out of range should show up for that matter. Limp mode doesn't appear as a code though, it's a protective measure to keep the engine from eating itself when it doesn't have good data.
I've had my truck 2 weeks and put a new fuel filter in it as matter of practice (original was black). Assume the previous owner didn't, because they were selling the truck.
Draining the water out of the filter can be done in dress clothes if you can reach the valve. If it's full of water, you'll get rough running and maybe some white smoke when it's acting up. Stick a clean catch pan under the oil pan and crack the valve for 20 seconds - see what it looks like.
Any mechanics/experienced people in/around NH willing to help diagnose?
You want MAP on the list, not MAF. I'd also get rid of the first EBP on the list, it's just confusing.
Check your IPR tinnerman nut - make sure it's there. When the ICP sensor fails, the PCM ignores it and fills in the value with what it thinks it should be. Check your ICP sensor for oil in the connector. If oily, I'd clean it up with electronic contact cleaner and try again.
Took the truck for a drive, below is the MAX ICP and IPR values at wide open throttle - wont go anywhere past these ICP and IPR values. I tried to run a KOER Contribution Test and it stops the test because of the ICP code (P1284). Can a bad ICP *limit* the pressure getting to the motor and stopping it at 2465.7 psi? The IPR does not go above 33.59%. Both the ICP and IPR were just replaced. The ICP was an aftermarket part, and the IPR was motorcraft oem.. can the ts chip limit these values by any chance - i tired on all positions and same max values - thoughts?
A black fuel filter is an indication that you are getting oil in your fuel system. The black is from the soot in the oil. How? Bad injector o-rings allow high pressure oil to push past the bad o-rings and mix with the much lower pressure fuel (3,000psi vs approx 50psi fuel). Check your coolant de-gas bottle. I'll bet you will see black gunk in there, indicating a similar contamination of the coolant, with soot, by the same means/mechanism mentioned above.
My bet would be that the socks in your fuel pickup are getting plugged. Every symptom echoes what I had going on. Time to do the h and h mod.
You can disconnect the fuel pump aft side and blow few pounds of compressed air thru the line and see if the problem dissolves momentarily. (it will come back if that's the cause) It's a simple free 20 minute diagnosis.
My truck did exactly what your laying out.
Denny
Denny
