1992 No Start
1992 No Start
Hi all, I have a 1992 F250 460 backed by a e40d with a crank no start issue. I do not see spark at the plugs, rotor cap or coil. So far I have checked/done:
Fuses good
Around 37 PSI fuel rails
11.78 volts at injectors
Unplug map, no avail
Ignition coil replaced, no avail
TPI replaced, no avail
Battery ground is good
No air restriction
Full of oil
Coolant is full
New battery recently
EEC relay was swapped with other relay under dash
Newer plug wires
Timing chain is not snapped
New distributor
Check to see if it had codes, reading all systems good
I'm about to lose my mind and really need this truck running. I could really use an expert on these trucks help, thank you
Fuses good
No air restriction
Full of oil
Coolant is full
Newer plug wires
New distributor
bozo4ford
1983 - 2012 Ranger & B-Series
08-13-2003 01:26 PM
