Barn Find 52 Mercury M3
#33
#35
#37
The Dana 60 is installed and I haven't set up the pinion angle yet. I didn't measure it, but it looks about 20 degrees up. I was told to set it at 2 degrees down from the angle at the center bearing flange. Does this sound correct? I want to have the pinion angle set before I send my driveshaft out to be rebuilt.
#38
#39
#40
I looked over your thread before deciding on a modern trans. I went to McMaster-Carr and looked over the linings. What thickness do I need? What rivets should I use?
I might as well use the T9 cover, since the T9 is getting scrapped.
I set my pinion angle at 2 degrees down from the flange at the trans, but since I did a couple of other mods, I went with a one piece driveshaft.
I decided on a short/wide bed. I used a z-cut with fish plates.
I also decided on satin black on the wheels with ribbed trim rings and original caps.
The bed and running boards are getting cut next. 8 inches out of the running boards. 8 inches from the front of the bed and 10 out of the back.
#42
I can't see a rear mount on your T98. Does it have one? If not, you have a later T98 that went to a bell housing with ears for rear mounts.
As far as the brake lining I think I went with a high strength or high heat type that was 5/16" thick. I had to machine my drum down so I probably could have gone 3/8" thick.
The rivets are brass tubular type same size as holes in band. Length to be determined by thickness of band and lining taking into account the depth you countersink the heads. Sorry I can't be more specific. I'll look to see if I can find my paper work for part numbers.
#43
[QUOTE=Scotty's 52 F3;16811762]I can't see a rear mount on your T98. Does it have one? If not, you have a later T98 that went to a bell housing with ears for rear mounts.
Scotty, thanks for the info.
The T98 came out of a 56 C500 COE with a Y Block. I have the bell housing and the bellhousing does have mounting ears. Will I be able to use this transmission? Can I get the rear mount?
#44
