49 F1 Belts Options (5/8 or 3/4)
Old 03-31-2016, 03:22 PM
ddiaz12's Avatar
ddiaz12
ddiaz12 is offline
I read through previous threads on this subject but didnt see the answer to my question so any help would be appreciated. I realize the size should be 3/4 for my 49 F1 8BA pulleys but all the replacement water pumps come with 5/8 pulleys. My crank, generator and fan pulleys are 3/4s and I do not have the original water pump pulleys. I plan to run the shorter 3/4 belt from crank to fan. Has anyone run the 5/8 belts across the crank, generator and water pumps? Or did you run the 3/4? Or did you swap the WP 5/8 pullys for the 3/4?
Old 03-31-2016, 05:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
'51-on Car pumps are 5/8", Truck pumps are 3/4". If you look at pumps with 5/8" sheaves, look at the motor mount area. They won't have the "foot" like truck pumps. Cars from the '30's thru '50 were the same as trucks.
Old 03-31-2016, 05:19 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Old 03-31-2016, 06:07 PM
ddiaz12's Avatar
ddiaz12
ddiaz12 is offline
Its hard to tell from pic but these are RT pumps with the foot to mount to the motor mount. I will send another pic in a bit when i get home.
Old 03-31-2016, 06:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, I can see the mount, they are truck pumps. Car pumps almost completely lack a foot.
Where are you seeing Truck pumps with the narrow belts?
Old 03-31-2016, 06:43 PM
ddiaz12's Avatar
ddiaz12
ddiaz12 is offline
The part number for the pumps are 8RT-8501 and here is a link from DC:
Water Pump - Right & Left | Dennis Carpenter Ford Restoration Parts
which specify 5/8 Wide Belts for 1948-52 truck. Do you know of another part number for the water pumps that would come with the 3/4 pulleys?
This is a 3/4 belt on the 5/8 pump. Please note the pump foot on motor mount.
Measuring the pulley, looks like 5/8
Old 03-31-2016, 07:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Sure does look like 5/8 at the sheave, but the 3/4" belt doesn't look wrong on it either. They do stick out a ways. Let's see what others who run the fat belts say (I run the Car belts, long story). NAPA shows a belt that is closer to 5/8, too.
https://www.napaonline.com/napa/en/p...544_0117360645
Old 03-31-2016, 08:12 PM
ddiaz12's Avatar
ddiaz12
ddiaz12 is offline
I've searched all shops that I could and they all sell the 8RT-8501 Truck WPs with a belt width of 5/8, which is the WPs that I have. Yet my crank, fan, generator measure 3/4. I assume others are using these pumps on their F1s? I can't imagine swapping out all your 3/4 pulleys to match the WP 5/8. Maybe I need to find some original pumps and swap my wp 5/8 pulleys for the original 3/4 pulley.
Old 03-31-2016, 08:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Do you have the old belts? I just measured the WPs, generator, and crank pulleys on an 8RT, and they are the same as yours; 5/8" on the WPs and the others are more like 3/4.
Old 03-31-2016, 10:18 PM
ddiaz12's Avatar
ddiaz12
ddiaz12 is offline
Unfortunately I dont have the old belts. So what belt width are you running on the WP, crank and generator? The 5/8 width 54.5 length belt?
Old 03-31-2016, 10:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I can't help in that regard, because my engine uses the narrow (Car) belts. The Parts books all say you should use the 3/4, I'd try it.
Old 03-31-2016, 10:57 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
I'm using 5/8 belt on mine, no problem. The other pulleys have enough depth. My flatty has aftermarket pumps.
Narrower belt needs to be slightly shorter.
Old 03-31-2016, 11:03 PM
ddiaz12's Avatar
ddiaz12
ddiaz12 is offline
Thats good to know about the narrower belts needing to be shorter. I figure I will try the 5/8 belt around the crank 3/4, gen 3/4 and WPs 5/8. I will keep the fan and crank at 3/4 since have the 3/4 belt already.
Old 04-02-2016, 12:49 PM
ddiaz12's Avatar
ddiaz12
ddiaz12 is offline
well after much deliberation (in my head) I went with an 11/16 width and 53 7/8 length belt from Napa. I figured its a bit bigger than the 5/8 and still smaller than the 3/4 which sits better in the WPs. Im still a few months from firing it up so we will see how it goes.
Old 04-02-2016, 01:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I didn't know they made belts in 11/16! Should be fine.
Quick Reply: 49 F1 Belts Options (5/8 or 3/4)
