Gauges not working
Old 03-31-2016, 02:29 PM
badaz4570's Avatar
badaz4570
badaz4570 is offline
Gauges not working
My fuel gauge isn't working and temp gauge isn't either. I couldn't find a dedicated fuse for gauges and all fuses look good. Any suggestions? Thanks.
Old 03-31-2016, 02:37 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
Check the position of your ignition key and make certain it has returned to the appropriate position. With the engine running, just slightly wiggle the key and look for the gauges to suddenly come to life. This is not uncommon as the mechanical ignition switch [where the key goes] can stick.
Three gauges are controlled by the ICVR and if it does not get power [during starting cycle the power is disrupted], the gauges fail to work. The 3 gauges are the temperature, oil pressure and fuel gauge. The ammeter is on a different circuit.
Open this link: https://www.ford-trucks.com/forums/1...mechanism.html
Old 03-31-2016, 02:46 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
David is correct. To add to that, this page has info on troubleshooting the gauges: Fuel Tank Selector & Gauges - Gary's Garagemahal
dmags
6.7L Power Stroke Diesel
09-07-2014 06:50 PM
Josh88Ford
09-12-2012 08:34 AM
caiati
01-09-2012 08:29 AM
LRSTony
01-02-2011 12:08 PM
tolie77
03-17-2010 08:28 PM
Quick Reply: Gauges not working
