352 converting to unleaded fuel
on
I would just go ahead and run your unleaded fuel in your engine just the way it is. I have ran a lot of older equipment(yes even some older than 1965) on unleaded gasoline and never had a problem.
For what it's worth, I have a 1965 F100 with a 352 that has been sitting for several years that I plan to get going this summer. I never considered, and still don't, doing anything to the heads or valves.
Unleaded
The valve seat recession that you are concerned with was mostly a problem in the 1970's before the refiners got a handle on making unleaded fuel. At 8.9-1 compression that engine should run on the current fuel just fine. The only thing that might be a concern is that %%%#$^ ethanol in it. If they even use it in NZ. There might still be some parts in the system that won't get along with that stuff.
on
Monahan77
09-07-2015 09:45 AM
Deen Hylton
01-07-2007 06:07 AM
