2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
We Own Work: My 2017 Super Duty Experience
Old 07-28-2016, 06:46 AM
porthole's Avatar
porthole
porthole is offline
H'mmm, this color could grow on me.
Don't know if this came up yet, the reason the wide track was eliminated for 2017?
  #1112
Old 07-28-2016, 06:47 AM
porthole's Avatar
porthole
porthole is offline
Are the yellow jounce bumpers in place of the overloads, or are there still overload tabs on the frame (that have rubber bumpers that 'disappear' with use) ?
Originally Posted by UGA33
450 blocks and conventional hitch that requires no weight distribution.
  #1113
Old 07-28-2016, 06:50 AM
porthole's Avatar
porthole
porthole is offline
What exactly are we looking at here?
Is this a rubber damper for the hitch assembly?
Kind of looks like the MOR/ryde rear spring hangers I have on my truck.
  #1114
Old 07-28-2016, 07:00 AM
Rasalas's Avatar
Rasalas
Rasalas is offline
Originally Posted by troverman
FlexFuel gives considerably better performance (increases power) but with considerably worse fuel economy. I ran it a few times in my 6.2L trucks. Although it's cheaper than gasoline, the mpg is so low that running costs are cheaper with gas. But you can feel the stronger engine output.
Thanks. I have never talked to anyone who has tried it. Usually there is a downside to something which may appear to have a benefit on the surface.
  #1115
Old 07-28-2016, 07:03 AM
UGA33's Avatar
UGA33
UGA33 is offline
Still has overloads.
  #1116
Old 07-28-2016, 07:04 AM
UGA33's Avatar
UGA33
UGA33 is offline
That is a vibration dampener.
  #1117
Old 07-28-2016, 07:18 AM
troverman's Avatar
troverman
troverman is offline
The air intake tube from the air filter to the intake manifold looks *substantially* larger than what we have now. In fact, the entire design of the air filter box looks pretty different - somewhat rounded instead of square.
  #1118
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
Speaking about vibration dampening -
Have they managed to finally solve the SuperDuty Hop at 42 MPH?
  #1119
Old 07-28-2016, 07:30 AM
porthole's Avatar
porthole
porthole is offline
For the hitch?
Forgot about my other question - With the DRW loaded, heavy trailer and 2500 pounds or more ion the pin, is there still a driveway vibration. And if so, is it more pronounced with the the heavier you foot gets?
Mine was bad, had the driveshaft changed and now it is still there but tolerable.
  #1120
Old 07-28-2016, 07:34 AM
porthole's Avatar
porthole
porthole is offline
Pricey option, but in the scheme of things, something I would probably order
Do they work with the tailgate step and pole (looks like it in the picture)?
Do they extend further then what is on display?
Capacity?
Pics of the optional ramp setup.
  #1121
Old 07-28-2016, 07:50 AM
Rasalas's Avatar
Rasalas
Rasalas is offline
Capacity?
The ability to stow these on board looks nice but that is a huge angle at the top of the ramp. I purchased a pair of aluminum ramps from CT for around $200 which are longer and arched rated at 1200 lbs. The arch makes a huge difference at the tailgate since the transition is gradual all the way up the ramp and then almost flat at the tailgate. Does not seem like much until sitting in the seat of a relatively tall side by side and then up 40 inches in the air too. Steep ramps also lead to traction issues if wet without a running start and that too is not a place to be slipping. I like the connection at the tailgate.
  #1122
Old 07-28-2016, 08:10 AM
Mayberry's Avatar
Mayberry
Mayberry is offline
Josh,
Can you check a few more 25/350 SRW roof heights? Maybe with clearance lights?
Does High Capacity Towing affect the heights? 18" or 20" wheels?
Thanks... Must be a blast!
  #1123
Old 07-28-2016, 08:16 AM
petei's Avatar
petei
petei is offline
Can you check if on f350 with no 5th wheel package the indentation for the pucks are visible?
  #1124
Old 07-28-2016, 08:24 AM
troverman's Avatar
troverman
Agreed. The factory ramps look way too steep. I like how they won't slip back, much easier than hooking straps to your hitch, but I already have a pair of Reese folding Farm & Ranch ramps with a 1500lb capacity.
  #1125
Old 07-28-2016, 08:48 AM
fzrider998's Avatar
fzrider998
fzrider998 is offline
I know several people already commented on the F250's low payloads reported on some of the window stickers. I was hoping to see numbers around the 3K mark, which would follow what the '16 Payload Selector tab has. So maybe the numbers would be higher in an XLT SCab, LB configuration. Obviously these trucks on display are optioned to the hilt, so they're going to chew into payload capability.
I know, I know....some people from Alaska can't wrap their minds around a purpose for the F250, but believe it or not, there are a lot of us who want more capability than a F150, but don't need the F350...and we even want a gas engine because we don't tow much. (I'd love a diesel, but unfortunately, its too expensive of an option for me to justify - add in the extra risk of very costly repairs out of warranty - and also add in that most people say if you're not working it hard, its more harmful to the engine).
I might be out of luck on height, too. These new SD's are tall buggers. I have standard 7' garage doors and also use a city parking garage twice a month which has a 6'11" height allowance. I'm starting to feel like I might get cheated out of a new SD.
How much bigger will these trucks be in 10 more years? It'd be interesting to do a side by side spec sheet comparison of the dimensions of the '17 and, say an '04. (choosing that one since I owned one).
Final conclusion for me, though? These trucks look the business, guys. Holy heck are they good looking trucks. And I want one in the driveway...now!
Quick Reply: We Own Work: My 2017 Super Duty Experience
