Rear Wiindow Slider Sealant - Ford Truck Enthusiasts Forums
Old 03-30-2016, 05:58 PM
Rooster403 Rooster403 is offline
Rooster403 is starting off with a positive reputation.
OK, folks, I am about to replace my Ford, (Carlite), Rear Sliding Window in my 2003 F150 Regular Cab. The previous unit was damaged and leaking. I need to know what is the recommended Foam Core Butyl Sealant to obtain. Near as I can determine, the Darcy 8mm round butyl tape will fit just fine. Looks like I'll need just over 12 feet but it only comes in 10 foot rolls. However, Amazon has it listed and not very expensive, about 6 bucks per roll.
Most vehicles today use the urethane, however, this body flexes enough that Ford recommends the butyl. Does anyone have a recommendation on another brand of products to use; 3m, etc.? Thanks for the feedback. Rooster
Old 03-30-2016, 06:25 PM
kd4gij's Avatar
kd4gij kd4gij is offline
kd4gij is starting off with a positive reputation.
Old 03-30-2016, 10:15 PM
blupupher's Avatar
blupupher blupupher is online now
blupupher is starting off with a positive reputation.
Quote:
Originally Posted by kd4gij View Post
^^ This ^^
Proper windshield installation procedure question 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-16-2016 07:55 PM
Rear window seal... a mess deezdrama 1968-2013 Full Size Vans 1 08-01-2016 07:50 PM
Roof leaking - factory weld joint / sealant ? DET17 Aerostar 18 01-06-2016 04:35 PM
1950 door anti rattler's Skalywag 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 07-09-2015 11:49 PM
Windshield Leaking jetdoc 1999 - 2003 7.3L Power Stroke Diesel 4 05-22-2015 06:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
