No power to the fuel pump 2011 F250 Super Duty 6.2 L
03-30-2016, 04:46 PM
on
I've had my truck sitting for over 3 months. I replaced my fuel pump because I thought that it was the problem and after it did not start checked power to the fuel pump and their is none what can the problem be???
03-30-2016, 07:49 PM
I would have checked the fuses before replacing the fuel pump.
03-30-2016, 07:58 PM
on
I checked fuses and relays before replacing the fuel pump and everything was fine I even had power at the the fuel pump... I have checked everything and I'm losing power at the fuse panel...My truck doesn't have an inertia switch and I was told they have an inertia relay inside the fuse panel but that it isn't replaceable and that maybe the problem...can anyone tell me how to check if that is the problem
03-31-2016, 06:01 AM
on
Maybe a mouse ate some wires or you have a bad ground or something.
03-31-2016, 06:24 AM
Look for the fuel shut off button. It may have tripped for some reason.You will have to look in the owners book to find it. A fuel pump should last for more than 5 years.
myredF250
1999 to 2016 Super Duty
03-25-2020 07:14 AM
lamm72
02-25-2017 07:55 PM
LIve Life Fast Cars
1983 - 2012 Ranger & B-Series
12-24-2015 10:32 AM
bicounty
39
02-24-2015 09:41 PM
unseenthings
05-09-2006 02:35 PM
