Tried to burn some bad gas in my truck now have fuel problems..
Long story bear with me..
Our old hunting truck had been sitting for about a year and a half and the gas in it smelled bad, so I siphoned it out of the truck (about 8 gallons) and decided the best way to get rid of it would be to put 4 gallons in each of the tanks on my 88 F-150 with the 4.9 I6 top it off and burn it. Well long story short it ran fine for about 100 miles, then started to spark knock some under load now its missing on 1 maybe 2 cylinders and running awful. I replaced the fuel filter already and that didn't change anything, but what ran out of it looked bad. I've burned one of the tanks and filled completely with fresh gas and some Berrymans B-12. Hasn't changed anything.
Did some trouble shooting today. I have 50psi fuel pressure at the rail both running and with the key on, which is right for the 4.9. Changed the plugs out, which only had a few thousand miles on them. All were dry and had an odd orange tint to them looked like varnish from the bad fuel. Ran the OBD I scanner on it and only faults were for EGR (been disconnected for years) and a code 44 'thermactor issue'. Changing plugs didn't affect how it was running at all. I'm thinking injectors are the only option left?
68f250360
Alternative Fuels, Hybrids & Mileage
04-24-2009 02:31 PM
