4cyl 5.8
The new harness had a couple shorts in it. Repaired, reinstalled, pulse at all injectors. Pulled the rail & injectors, #8 not firing. Replaced it, watched all injectors spray fuel & put it all back together. Attempted to start & the solenoid went out. Replaced & attempted to start, now no fire from the coil. Arrrgghh!!! Found the bad connection & it fired right up. Still missing on #1. Fire at the plug so I replaced the plug. Still missing on #1.
Called it a night at 1:30 this mornin.
Perhaps the return side is grounded and always open?
Or you have a weak spark problem.
sunk_boat
04-12-2013 06:58 PM
Frost13
1983 - 2012 Ranger & B-Series
08-02-2004 07:06 AM
