Motor mounts 1952 F1
I have started working on a 52 F1 that I am putting a 302 engine and a C4 automatic transmission into. My son has purchased a cross member and motor mounts from Mid Fifties some time back. I have installed the motor mounts to the engine and have put the cross member in the truck frame. I have laid the engine and transmission in the frame to check for the drive shaft tilt and also see it the intake is level and it is.
My question is on mounting the cross member and the motor mounts is the bottom bolt for the shock mount suppose to go through the cross member and then you drill the other three into the frame? Another question is do you weld the pipe cross member to the plate you bolt to the frame or does it need to pivot with the engine torque?
Here are a few picks of what I am talking about I hope you can see.
Thanks in advance for any information that will help,
Larry
Larry
fiftford
10-18-2015 07:44 AM
41505379
06-23-2014 01:48 PM
jims99
05-26-2008 09:55 PM
