Help LUG NUT & Washer 15x10 MT forged Alcoas
I thank you in advance for the answer.
I have the above mentioned 1pc 15x10 3000lb rated MT -ALCOA wheels.
MT can only tell me it uses a 60* conical nut. That I know. I called Alcoa but that was a dead end as well, had a good feeling thT was going nowhere.
Can someone tell me the PURPOSE of washer 'recess' is on the backside of the rims? Is this a sacrificial piece to prevent galvanic corrosion BT the wheel and my rotors/drums? I'm putting them on a 76 bronco with Duff long arms. Is the washer a structural aspect of the wheel when on the stud? I'm assuming this recess is for a washer of some sort. Please provide any info . Oilite washer? Steel or aluminum would kinda cancel out the galvanic corrosion aspect I brought up....
SIZE & type washer PLEASE?
Purpose bc I like to know WHY?
Thanks for your help!
The only Washer i know of use on aluminum wheels is when the "MAG" style lug nut is used
I suspect that it's just so the wheel contacts the hub farther away from the lug. But that's just a guess.
But there would be no problem putting those wheels on a '76 Bronco. There would be no washer of any type used. Just the wheel and the lugnuts over the studs.
NothingSpecial, YES I am asking about the 'counterbore'. Here are some pics I took last night. Along with some info on the wheel fwiw.
* Alcoa Forged - Max Load 3000lbs -Max PSI COLD 95lbs
U.S.A. - 0699 - PART NO. 250400 - 15 X 10 J *
I have this style wheel in 7-1/2" & 8-1/2" as well. The 7-1/2s do have a 1/2x20 nut that does "sleeve" the stud to center the wheel. They are not the Anson 'slots' but made by Rocket Industries IIRC.
gooseman80
1999 to 2016 Super Duty
03-06-2016 12:22 AM
78bigunns
12-24-2012 12:08 AM
raytasch
10-02-2012 09:36 PM
paradiddle
10-30-2002 02:32 AM
