Ford Sync wont update
#121
Actually! Thanks to B-Pod I was able to get this working. Here is the Trick he mentioned in a previous post.
"Try this only at your own risk. I'm not a programmer, and I have no special knowledge at all on this topic. I just used curiosity, tips from others and a hunch. It worked on my wife's 2012 Expedition with Nav.
From 'install.lst' I removed the text in red below and left the remaining text as is. This tip came from another forum found by searching the web for 'E1BT-14D546-GA'. Removing this unnecessary text allows the disk to be read, but others reported that the install still failed with a message other than "File Not Found."
; USB Update Application !
; USB Installation !
; Microsoft Windows Automotive !
[Windows Mobile For Automotive 5.8]
Item1 = 8L2T-14D546-AF
Open1 = SyncMyRide\8L2T-14D546-AF.cab
Item2 = E1BT-14D546-CA
Open2 = SyncMyRide\E1BT-14D546-CA.cab
Item3 = E1BT-14D546-GA
Open3 = SyncMyRide\E1BT-14D546-GA.cab
Item4 = FJ5T-14D546-UA
Open4 = SyncMyRide\FJ5T-14D546-UA.pks
Item5 = E1BT-14D546-FB
Open5 = SyncMyRide\E1BT-14D546-FB.cab
Item6 = E1BT-14D546-BB
Open6 = SyncMyRide\E1BT-14D546-BB.cab
Item7 = E1BT-14D546-AA
Open7 = SyncMyRide\E1BT-14D546-AA.cab
Next, on a hunch, I edited the text in red below of the 'autoinstall.lst' file to match the files in the SyncMyRide folder.
[Windows Mobile for Automotive 5.8]
Open1 = SyncMyRide\8L2T-14D546-AF.CAB (changed to cab)
Item2 = E1BT-14D546-HC
Open2 = SyncMyRide\E1BT-14D546-HA.cab (changed to 'HC' to 'HA' to match the Item2 file in the 'install.lst' file).
#122
4.4 I have tried 2 different drives everything appears correct just keep saying files not found all files are unzipped the correct files are on drive I have not done a master reset
#123
Cara
#125
#127
#128
Cara
#129
#131
#132
#134
The 4.4 update has been pulled and no longer available to install. We are unable to speculate when future updates will be released.
Cara
#135
Just created an account and wanted to post here as a notice that other Fords, apart from the trucks are having this issue too. I'm in the exact same situation as many others here where my 2012 Fusion Sport with basic sync simply won't update, and responds with 'File Not Found'.
I have actually tried the tricks provided by B-Pod and to no avail.
If anyone ever figures out a definitive way top fix this, I'm all ears.
