Not what I expected to find
So chasing down long crank and rougher idle on sons 99 SD (Lil Foot).
Low ICP....Replaced ICP, better but not fixed
Low IPR at crank...Replaced IPR, no change
Talked to friend he said injector o-rings, or maybe LPOP, but most likely O-rings
Ordered up o-rings, hpop reservoir gaskets, and LPOP from RiffRaff.
Replaced 'the LPOP, no scoring. Gears had a little wear, 228k miles.
Started pulling covers and working on injectors.
This is what we found.
These are the worst. 7 of 8 were damaged.
All o-rings replaced. Life is grand. Ran out of time to finish up, we'll wrap up tomorrow. Got to spend the day with my son (21) doesn't happen very often any more.
Also injectors only have 24k miles on them. Going to contact the vendor.
Happy Easter all.
Keith & Craig
Happy Easter all.
Keith & Craig
Download the inector o ring tech sheet from RiffRaff. It's very comprehensive. I took the alternator off out of convenience. It's not as imposing as it looks. Make sure you have or get a minivac or some kind of vacuum to evacuate the cylinders.
Let me know if you have any questions.
Keith
Racecarhauler
10-20-2009 01:41 AM
