1997 7.3 acceleration problem
Old 03-23-2016, 09:26 PM
bettywhite's Avatar
bettywhite
bettywhite is offline
Cool 1997 7.3 acceleration problem
Alright, so i had another thread on here about a problem with my 1997 f250 7.3. first off, its a 97 automatic with 150k miles. the truck originally had a ts 6 position chip but i took it out tonight to see if my problem would be gone, but it still happened.
so here is my problem, coming from a stop sometimes (and i mean its completely random when it happens) my truck will have a problem accelerating. when i press the gas, the truck will take off very slow and when i put my foot into it, i will see the rpms jump to 2k but the truck still wont accelerate any faster. eventually the truck wiill kick in and drive normal. this problem doesnt exist at cruising speeds, just upon acceleration. so the ts 6 position chip wasnt my problem and now i will be reinstalling it.
my transmission fluid is a little brown and has a burnt smell to it but its not bad and its operates at about 160 degrees. so i will be doing a flush but i dont know if thats my problem. i also replaced my fuel filter tonight my icp sensor. any suggestions?
Old 03-23-2016, 09:29 PM
MI02SVT's Avatar
MI02SVT
MI02SVT is offline
Sounds like a trans issue the fluid should be red not a little brown and burnt smelling
Old 03-23-2016, 09:32 PM
bettywhite's Avatar
bettywhite
well i dont think the fluid ever been replaced so it could just be normal ware on the fluid. the tranny doesnt get any hotter than 160
Old 03-23-2016, 09:45 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,183 Likes on 812 Posts
Thats the reason the e4od trannys got a bad rep, due to neglected service, do a fluid exchange asap before it completly gives out.
Old 03-23-2016, 09:48 PM
bettywhite's Avatar
bettywhite
So do you think I need a rebuild?
Old 03-24-2016, 08:39 AM
MI02SVT's Avatar
MI02SVT
MI02SVT is offline
Flush it and put some new fluid in it if it still does the same thing then yes there's a fine line with it being wasted and still good just don't drive it anymore until you flush it and if you do drive it don't floor it to get it moving you're just making the problem worse
Poorboy04
11-08-2013 09:21 AM
MrMontana
08-26-2013 05:14 PM
tryagn5
1999 to 2016 Super Duty
11-04-2009 07:55 PM
jfrank
11-05-2003 02:56 PM
jimb206
10-14-2003 08:03 PM
Quick Reply: 1997 7.3 acceleration problem
