1949 M-68 (F-3) Modern aftermarket rims - Ford Truck Enthusiasts Forums
Old 03-23-2016, 08:29 PM
Jeffrey Rempel's Avatar
Jeffrey Rempel Jeffrey Rempel is offline
Jeffrey Rempel is gaining momentum as a positive member of FTE.
I have done a lot of reading and searching on this form and I can't seem to find any reference to current production aftermarket wheels that will fit on a 1949 Mercury M-68 (F-3). Have I just missed them or are there none available? My truck has what I believe to be widow makers (maybe someone can confirm?) and I would like to replace them with something safe.
Old 03-23-2016, 09:34 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Yup, those are 17" widow makers. No source I know of has been found for "aftermarket" modern wheels to replace them. Your 14" rear brake drums create us the challenge of finding other production wheels that will be safe. We know that 1956 to 1966 F-250s had optional 17.5" and 19.5" wheels that are pure and correct looking replacements. Even accept your stock hub caps. Finding sets of either will take some looking. Others have found that mid to late 1990s era Dodge 3/4 ton wheels are a bolt on fix. But they a wider and need to be spaced out a bit to not rub on the inner front. I've tried to find specifics including manufacturer and part numbers, but have yet to do that. Others have had custom wheels built using your stock centers fitted to modern tubeless 17" outer rims. Stu
Old 03-23-2016, 09:57 PM
Thanks Stu for confirming that. I have read that a Dana 60 swap gives more options for 16" rims. Is it possible to just swap the drums on my existing rear axle? Is it worth it or is a Dana 60 my best bet?
Old 03-23-2016, 10:07 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3 Scotty's 52 F3 is online now
Scotty's 52 F3 has a good reputation on FTE.Scotty's 52 F3 has a good reputation on FTE.
I just went ahead and swapped a Dana 60 from a 1972 F250. You need a 68-72 for correct width.
It bolted right in. I just had to shorten the drive shaft, used an adapter for the brake line and a conversion U-joint. I also cut off the F250 shock mounts and used stock F2 shock mounts.
You have way more gear options and brake drums are available. I think it's worth it. I can post pics of the swap if you need them.
A 1972 and earlier F-250 Dana 60 swap is a well documented swap. And can give a much taller final drive ratio for better highway cruising. Swapping backing plates and drums is an option if you can find a donor USA spec F-2. They have 12" drums. No F-2s were sold in Canada. But even if the F-2 donor is found, it's no easy task to find new F-2 drums if needed. Stu
Old 03-23-2016, 10:25 PM
CHUCK48-50's Avatar
CHUCK48-50 CHUCK48-50 is offline
CHUCK48-50 has a good reputation on FTE.CHUCK48-50 has a good reputation on FTE.
If you want it to look stock, you can swap backing plates and drums from any 1957-72 F-250 onto your original rear.
Chuck
Old 03-24-2016, 08:40 PM
Does anyone know if the rear diff from a 91 dodge 250 would be a bolt in?
Old 03-24-2016, 08:55 PM
Too wide. You need an axle from a 1972 or earlier F-250 having the SAE standard 34" frame width, or from a later chassis/cab through mid 1970s (I forget exact year) that retained the 34" width. Stu
Old 06-08-2016, 03:48 PM
I just stumbled across these. They are from a old chevy. Does anyone know if they will fit?
http://www.ebay.com/itm/112012666310
Old 06-08-2016, 04:06 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Scotty's 52 F3 View Post
I just went ahead and swapped a Dana 60 from a 1972 F250. You need a 54-72* for correct width.
*Spicer/Dana 60 introduced in 1954 F250, but some 1954/55 F250's also came with the Timken A150 rear axle.
Spicer/Dana rear axle ratios: 1954/56 could be: 4.56-1; 4.88-1 or 5.87-1 / 1957/72 could be 4.56-1 or 4.88-1.
4.10-1 introduced in 1963; 3.54-1 introduced in 1966; 3.73-1 introduced in 1967.
Drum brakes: 1956/58 & 1959/65 F250 2WD's have 12 1/8" x 2" front/rear brakes as do some 1966/72 F250's with GVWR's under 7,500 lbs.
1966/72 F250 Camper Specials (all 2WD) and like F250's with 7,500 lbs. GVWR have 12" x 2 1/2" front/rear brakes.
If 1968/72 F250 2WD's have optional dual piston caliper front disc brakes, the rear drum brakes are 12" x 2 1/2."
Old 06-08-2016, 06:12 PM
Thanks for providing the diff ratios by year. That is really helpful. My best bet is probably to do the axle swap instead of trying to find wheels for the 14 inch drums.
Old 06-08-2016, 06:26 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
We did the Dana 60 swap after completing the restoration (they are never totally complete) . We also have 17" 1995 Dodge 3/4 ton rims with 1.5" spacers on the front . The Dana 60 with 3.54 gears is a perfect combination for us .
Old 06-08-2016, 07:24 PM
Quote:
With the 3.54 gears, I'm assuming stock 4 speed crash box, what are your rpms at 60 mph
Old 06-08-2016, 07:49 PM
Quote:
1957 58 59 60 66 8 Lug 17 5 x5 25 KH Chevrolet GMC 3 4 1 Ton Panel Wheel Set | eBay
Will not fit on the rear. GM wheels have a 4.625" center hole while Ford and others use wheels having a 4.78" center hole. Stu
Old 06-09-2016, 02:39 AM
Quote:
Originally Posted by truckdog62563 View Post
Too wide.
You need an axle from a 1972 or earlier F-250 having the SAE standard 33 1/2" inner frame rail width behind the cab.
Or from a 1973/77 F250 4WD (High Boy)...which I forgot to mention in post #10.
But despite the same frame rail width, you don't want a rear axle from a 1963/78 F350 & 1979 F350 2WD Cab & Chassis or 1973/79 F350 Regular Cabs on the 140" wheelbase, as they all came with Dana 70's.
1949 M68 zrae 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 06-19-2016 12:01 PM
1949-1951 Mercury Overdrive fifty-two_f1 WTB - Parts & other 0 12-27-2015 11:23 PM
1949 f1 to f3 Frame difference brooksdw 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 12-01-2015 03:02 AM
1949 Ford F5 Dually Rear Suspension Shake-N-Bake68 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-17-2014 07:14 PM
1949 Ford F1 oscardgarza 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 04-02-2013 08:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
